Backcountry Pilot • Northern Ca. TFR alert for Tuesday 02/13/07
4 postsPage 1 of 1
If ya'll are flying north of sac and you see a funny looking aircraft with no windows you might want to look for his F-16 wingman that will want to show you where you will want to land for a little pow-wow... ;-)
7/2891 ZOA CA.. FLIGHT RESTRICTIONS, BEALE AFB, CALIFORNIA, FEBRUARY 13, 2007 PURSUANT TO TITLE 14 CFR SECTION 99.7, SPECIAL SECURITY INSTRUCTIONS, AIRCRAFT FLIGHT OPERATIONS PROHIBITED. WITHIN A 10 NMR OF 390803N/1212615W OR THE MYV055006.7 UP TO AND INCLUDING 18000 FT MSL EFFECTIVE 0702131945 UTC (1145 LOCAL 02/13/07) UNTIL 0702132245 UTC (1445 LOCAL 02/13/07). EXCEPT AS SPECIFIED BELOW AND/OR UNLESS AUTHORIZED BY ATC: 1. ALL AIRCRAFT ENTERING OR EXITING THE TFR MUST BE ON A DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC CONTROL (ATC) FACILITY. 2. AIRCRAFT MUST BE SQUAWKING THE DISCRETE CODE AT ALL TIMES WHILE IN THE TFR. 3. ALL AIRCRAFT ENTERING OR EXITING THE TFR MUST REMAIN IN TWO-WAY RADIO COMMUNICATIONS WITH ATC. 4. NORTHERN CALIFORNIA TRACON, PHONE 916-366-4080, IS THE FAA COORDINATION FACILITY.
retired user offline
Good job posting the TFR including map! (how dey do dat?)
So what's the funny looking aircraft with no windows? Some kind of UAV?
Eric
thanks for the heads up, but there is no way a F-16 could fly slow enough to catch me...
Hammer offline
odds are you'll never see anything, however if your in the area, look for two slower chase ac and one contrail
sector15 offline
4 postsPage 1 of 1
