Backcountry Pilot • Nosing over with full stick forward??
20 posts • Page 1 of 1
Do you agree?
I totally disagree?
4
33%
Not sure?
8
67%
Total votes : 12
I have been flying a taylorcraft for nearly 15 years and was fortunate enough to have an instructor with nearly 30,000 hours in general aviation aircraft mostly taildraggers.
When he was teaching me to fly. He always said not to worry about nosing the airplane over due to pushing the controls full forward, because it will not happen. This of course, assuming you're not hitting the brakes or there is some other force involved.
I have found this to be true in my taylorcraft. I am just wondering, what everybody else's experience is??
tcraft offline
shawn coleman
2202T
tcraft f-22
thanks never saw it
tcraft offline
shawn coleman
2202T
tcraft f-22
Good topic though, I was wondering the same thing as you can see from that other topic.
Shawn:
Maybe you can ask your instructor if Zane can use his aircraft for the test. That's one way to determine how certain he is that it cannot be done.
I have a hunch that he'll decline the request.
My Champ will very likely have enough elevator, especially at take-off power, to drive the nose into the ground. The elevator and rudder are designed to be very powerful on most tailwheel aircraft. Well, on properly designed ones, that is; there are exceptions.
Jon B.
Jon B. offline
Sorry. I don't have a clever sig yet.
Jon B. wrote:Shawn:
Ask him! Ask him! I wanna try it!
Simple answer: It depends on the aircraft type.
Oh, yeah, and the loading.
Anything is possible if the pilot's head is far enough up.......oops, never mind, I already got chewed out for that comment. :oops:
Eric
I wish my instructor was still alive to explain his side of the argument. All I can seem to remember was that the thrust line would change so that consequently the elevator would lose lift and reach a happy medium. Like I said it all holds true for taylorcraft
tcraft offline
shawn coleman
2202T
tcraft f-22
tcraft wrote:I wish my instructor was still alive to explain his side of the argument. All I can seem to remember was that the thrust line would change so that consequently the elevator would lose lift and reach a happy medium. Like I said it all holds true for taylorcraft
The thrust line can't change! The prop is still bolted to the engine and the tail is still bolted/welded to the airframe. The aircraft's relative angle to the ground is irrelevant. Either the tail has enough leverage & influence to push the prop into the dirt or it doesn't.
Remember, the tail's function is to prevent the wing from tucking under. Its lift is down, not up. Increasing airspeed makes the wing want to tuck, and causes the tail to push down. Throwing in full down elevator (forward stick) will pretty likely cause the prop to eat the ground. I'm not going to try it with anyone's aircraft, especially my own.
If you travel along at cruise speed - or, since we're talking about take-off speed, use that - and shove the stick/yoke full forward, the airplane will nose down and (if it doesn't run out of gas) do an ugly outside loop. If it holds together in a fairly high negative-G situation, that is. Would it not do the same on the ground? I suspect it will, but again, I ain't gonna try it.
Jon B.
Jon B. offline
tcraft wrote: All I can seem to remember was that the thrust line would change so that consequently the elevator would lose lift and reach a happy medium.
I think what you're looking for is that the pitch axis is slightly different than in flight because the main gear are in contact with the ground.
Jon B. wrote:The thrust line can't change! The prop is still bolted to the engine and the tail is still bolted/welded to the airframe.
This is true, thrustline is design configuration, a relationship of the axis of thrust in reference to the airframe.
Jon B. wrote:Throwing in full down elevator (forward stick) will pretty likely cause the prop to eat the ground. I'm not going to try it with anyone's aircraft, especially my own.
Nobody is going to try this is their aircraft, nor is anyone suggesting anybody try it. This is a purely theoretical discussion about the behavior of a tailwheel aircraft. Don't get hung up on the stupidity of trying it vs discussing it.
The main point of this whole thing is that in some aircraft the relative wind is strong enough flowing over the tail, that while the main gear are contacting the ground, the effective tail arm is longer (since the pitch axis is moved forward to the gear contact points), and therefore exerts more moment on the tail. The elevator surface area is fixed and can only exert so much up or down force, which according to this theory is not enough to push the pitch angle of the aircraft beyond a certain threshold, and the aircraft can maintain a rolling stinkbug attitude without nosing over. I had also heard from people (in person) who had this demonstrated to them by an instructor, in a Citabria. There are obviously some variable factors that may cause the above to not hold true, like prop length.
well said
tcraft offline
shawn coleman
2202T
tcraft f-22
Zane
Bring this subject back up in January when the fog is 100"agl.
N18NV offline
N18NV wrote:Zane
And it's 27 below zero in Minnesota...
I know the discussion has to do with theory. I happen to disagree with the theory that the elevators are incapable of driving the nose down at takeoff speed. I don't care to fully test the theory, though.
I think, instead, I'll go put a new cylinder on the Kick-Ass Champ tomorrow. I burned one up a week ago and the new one arrived today.
Jon B.
Jon B. offline
Jon B. wrote:I don't care to fully test the theory, though.
Me neither ;)
Get that Champ flyin again...the nice flying wx is about to hit. You guys gonna do the Fall Colors run again?
Me neither ;)
Good grief! Where have I been?
Sorry for the delay; it was a long weekend. Yes, the Champ is in the air again. I have about 4 hours on the new cylinder. It's amazing how much more power you get from 4 cylinders vs. three! Note: having 3 of 4 cylinders firing does *not* generate 75% power!
I've not heard any official plans for the fly-out. I sure hope it's on. If not, I'll have to organize one, I guess. The north shore of Superior is mighty nice in the fall; it would be a shame to miss it this year (again).
If/when a notice appears, I'll post it over here in case there are others in the upper midwest that care to join in - MTV; you there?
Jon B.
Jon B. offline
Speaking of the northern Minnesota Fall COlors Tour...
http://www.supercub.org/phpbb2/viewtopic.php?t=11239
There's one (the 3rd annual) in the works!
Jon B.
Jon B. offline
I am a low timer so take heed- My experience is with Aeronca Champ 7ac 65 hp 75 hp and 7dc 85 hp. All of which will not nose over on hard surface runway take off with full stick forward- in fact this is the procedure taught to me by two seperate instructors.
Stick full up at throttle application- count to 3 - stick full forward (smoothly) hold on runway until 60- rotate- climb at 65-70mph. :shock:
Steve Rains offline
We get a lot of spammer users signing up for this site, 99% of them "robots" who scour the web looking for forums to spam, with names like Mike Lewis, Steve Thompson, etc.
I ALMOST deleted you Steve! Glad I didn't ;)
