Ok some professionals working on this but I’m impatient enough I’ll open it up to the infinite wisdom and kindness of the internet.
Started noticing engine surging/power oscillation on climb out, particularly at high DA. Plane is a cub with a Lyc O-360, Trailblazer CS prop, ignition is one mag and one electroair. Felt it first in the seat, sure enough manifold pressure oscillating with the surges. Engine data shows MP oscillation with about 10s period, up to 1-1.25” peak-peak. Digging into old data also shows it happens in a variety of scenarios—full power at sea level, economy cruise leaned out, etc. Also plenty of times when it doesn’t occur. Suspect it’s only noticeable in the seat on takeoff because I'm hanging on the prop and max vigilance, and I didn't see it on the gauge because who stares at that for 20 seconds. Have tried different mixtures, switching tanks, prop settings, fuel boost pump on/off, etc.
Prop seems to be behaving. Most promising theory to date was that a leak or sensor issue in the MAP sensor for the electroair was causing the electronic ignition to varying the timing and thus the engine power. Just ruled this out by disconnecting the MAP sensor, issue persists with static electronic ignition timing. Carb issue? Induction leak? (some suspicious EGT behavior). Oh one more stumper.. the fuel pressure (but NOT flow) sometimes seems to track the MP oscillation. Armchair experts.. weigh in!
Two engine data files here.. one cruise, one takeoff.
