alaskan9974 wrote: Just curious does anyone have field approvals on higher comp pistons on the 470s? Curious if I could get that past the fsdo. I heard of a few guys running them with approval up here but haven't seen the details
I got curious about the Bendix fuel injection & googled up this older thread.
Then got interested in high compression pistons...
The North Point XP470 (formerly known as the pponk 470-50) is 7.5:1 compression for 265 horsepower,
but Northpoint sez 8.5 pistons are optional for 275hp.
As long as you don't mind 100LL-only ops,
high compression pistons would seem to be a worthy change for a stock displacement 470.
There seems to be at least two ways to go:
1) the Norland conversion creates a carbureted 470 with 8.6:1 pistons, 260hp at 2625.
However, you must start with an IO-470 core.
2) Texas Skyways converts the 470U (230hp at 2400 rpm) into the O-470-U/TS, 250(+) hp at 2600.
However, you have to start with a 470U core.
Seems like IO470 pistons (8.6:1) in a regular 470 would be pretty easy,
but for whatever reason no one seems to have STC'd that change.
