I have a 1958 182 with the O470L, it was field overhauled long ago in calendar time but fairly few hours in engine time as the airplane only put a few hours on each year for the past decade or so. I fly it a lot more often now, usually once a week minimum. I understand that the infrequent use was definitely hard on the engine.
The engine runs fine, a bit low on oil pressure in the heat of the summer but fine in the cold winter temperatures. Doesn't burn or leak enough oil to lose more then a quart every couple hours or so. I've noticed recently that the engine becomes stiff and hard to move after it has been running, so much so that the starter will not crank it over. When cold the engine moves freely, propeller bounces when pulled down, normal, starts fine.
I haven't a clue where to start and am going to ask my A&P tomorrow but figured I'd ask just to dip into the pool of knowledge here. I don't plan to fly it till I at least roughly diagnose it as its scratching me the wrong way.
Thanks all.
