Tue Mar 01, 2011 11:11 pm
Pretty simple Joe, though everyone's would be different of course. The valve goes on the pressure, or supply, side of the waterpump, in my case a few inches before it enters the radiator, the 5/8" line goes through the firewall and to the heat exchanger/fan unit, which in my case is right under my panel between my knees in otherwise dead space: it is not in the way at all, even with the biggest boots I wear. The return line goes back through the firewall to a 1" x 1" x 5/8" tee (Rotax uses 1'' for their main circ lines) and the circuit is completed.
My snap action thermal switch (Graingers etc, less then 20 bucks) was mainly used because I already had some in the shop for my hot water solar projects, and it works the same here. The thermal switch is simply held in position (for good heat transfer) against the metal incoming fitting, and when it warms up the fan starts, and when it cools down it shuts off. Not really needed, but I like the auto feature, my woodstove fan does the exact same thing.
Mine was an afterthought, planned ahead I could have left an even more out of the way place under the panel, or even alongside the left or right side of the boot cowl. Although I already had a heat muff system in place, and left it there at least for now, you could go with this for your main heater and forgo the muff. Joel also mentioned a tuned exhaust for the 912S he is working on, it provides more power but is not so easy to put a heat muff on, that led to this hot water cabin heat setup. Hey I like having TWO heaters... I can always open a door if it gets too hot!
