Backcountry Pilot • Oil temp/oil press
Oil temp/oil press
12 postsPage 1 of 1
Oil temp/oil press
On a recent flight back from Nevada in level flight @ 9500' my oil pressure dropped to 34 psi as my oil temp rose to 204 deg f. OAT was 30 deg f . This was a bit alarming as the sun was going down and landing options were limited. 20-30 mins later the temp went back down to 185 and the pressure climbed back up to 40-41 psi. Green is 30-60 psi.
Anybody had similar situation(s) and what did you do to resolve them? New EI gauge and I believe it's accurate. 20 hrs on rebuilt engine ECI cylinders good compressions, Not a non congealing cooler. I'm seeing the oil temp all over the place from 185-200 up and down. I'm suspecting the Verna-therm.
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Re: Oil temp/oil press
could be the vernatherm, I had the same problem 2 years ago and a different vernatherm did the trick. Take it out and look very carefully at the seat. You will see a ring were it seats, if the ring doesn't go all the around it's not seating properly
Tim offline
I think is was that the oil cooler was congealed. Seen it alot with Continentals with front mount coolers. Try a piece of tape across the middle of the cooler and see what happens on a short flight.
Skydive206 offline
Ok I replaced the Vernatherm and It fixed the problem. Oil temp stays between 165 to 175. oil pressure stays between 42 to 46 psi.
Glidergeek offline
DG 400
Glidergeek wrote:Ok I replaced the Vernatherm and It fixed the problem. Oil temp stays between 165 to 175. oil pressure stays between 42 to 46 psi.
Hey, uhh...
What's a Vernatherm? :)
It's like a thermostat. It is open and lets cold oil bypass the oil cooler and when the oil warms it expands and forces the oil to divert to the oil cooler as the oil makes the rounds in the engine.
What 180Marty said.
Plus everything you might want to know about it, and cooling info is at:
http://www.sacskyranch.com/eng18.htm
bumper offline
bumper
Minden, NV
Husky A1-B
bumper wrote:What 180Marty said.
Ya I used that link to research this problem what a wealth of information. I'm thinkin of buying the CD they've got for sale.
Glidergeek offline
DG 400
If you're interested in learning more about your aircraft engine, I strongly recommend picking up a copy of the "Skyranch Engineering Manual" written by John Schwaner. I think you could read that book a dozen times and still learn something each time! :)
RDUStinson offline
108-3
Awesome, glad to hear she's all ready to "rock and roll"... Come back up, I owe you a burger this time... :)
Coyote Ugly offline
Track My Spot
"Awesome, glad to hear she's all ready to "rock and roll"... Come back up, I owe you a burger this time... :)"
I'd settle for directions to the closest hot springs. Then that burger & a beer or 2, :D Starting to get demanding aren't I?
Got 28 hrs on her now used 1 qt of oil in the last 12 hrs is that ok?
Glidergeek offline
DG 400
12 postsPage 1 of 1
