Skylane wrote:OK looking at Jeremys site and noticed, as I was looking at chronology, that some of the Maules have a -7, 0, ?,?, 48 degrees of flap. 5 notches, so what's up with the -7, and the 48 must be like hanging out a barn door.
Do you cruise with the -7, or 0?
Which gear do you like, oleo or spring?
Thanks, fly safe, Bub
Bub-
To add to what Jeremy said.... Yes when you go full flaps on the M6-M7 spesificlally the "long wing" you do have a Barn Door hanging out there and you are doin' some serous slowage. As is normal in aviation keeping things light works to your advantage so the weights diff between the Spring and Oleo Gear is a pretty hard pill to choke down, the stability you get from the "Wide" gear is nice as it is a foot or so wider than the Oleo gear but with that you have to deal with being out side the wheel tracks of some landing spots, kinda like driving down the interstate in a Geo and getting bounced around in the ruts of the 18 wheelers. I have been lucky enuff to have the chance to fly the M4,5,7 and MX7 with the "Universal Wing" The 4' sand 5's are much sporty'er feel than the Longer wing'ed M's having the shorter wings and larger Ailerons that give you a snappyer roll rate
Now the M6,7, MX7's with the 32'11'' (UNIVERSAL) and 33'10'' wings are very cool and you can slow these bad boys down and still have a pretty friendly sight picture over the nose.
I have had the pleasure of watching a M5 in the very skilled hands a proficient Maule driver Spank some long wingers at STOL fun so I know in the right hands the full line of Maules can perform very well loaded and light. There is more I could type but my fingers are about ready to fall off now as it is, I'm sure that Jeremy can correct anything that I have screwed up in this little run on sentence.
