Backcountry Pilot • One Long Flight!
One Long Flight!
6 postsPage 1 of 1
One Long Flight!
I'm sure a lot of you have already read this but I thought I would post it anyway.
* On December 4, 1958 Robert Timm and John Cook took off from McCarran Airfield, Las Vegas, NV in N9172B. Sixty four days, 22 hours, 19 minutes and 5 seconds later, they landed back at McCarran Airfield on February 4, 1959. The flight was part of a fund raising effort for the Damon Runyon Cancer Fund. Food and water were transferred by matching speeds with a chase car on a straight stretch of road in the desert, and hoisting the supplies aboard with a rope and bucket. Fuel was taken on by hoisting a hose from a fuel truck up to the aircraft, filling an auxiliary belly tank installed for the flight, pumping that fuel into the aircraft's regular tanks, and then filling the belly tank again. The drivers steered while a second person matched speeds with the aircraft with his foot on the vehicle's accelerator pedal.
Engine oil was added by means of a tube from the cabin that was fitted to pass through the firewall. Only the pilot's seat was installed. The remaining space was used for a pad on which the relief pilot slept. The right cabin door was replaced with an easy-opening, accordion-type door to allow supplies and fuel to be hoisted aboard. Early in the flight, the engine driven electric generator failed. A Champion wind driven generator (turned by a small propeller) was hoisted aboard, taped to the wing support strut, plugged into the cigarette lighter socket -- and served as the aircraft's source of electricity for the rest of the flight. The pilots decided to end the marathon-flight because, with over 1500 hours continuous running during the record-setting flight plus several hundred hours already on the engine beforehand (considerably in excess of its normal overhaul interval), the engine's power output had deteriorated to the point that they were barely able to climb away after refueling. The aircraft is on display in the passenger terminal at McCarran International Airport. Photos and details of the record flight can be seen in a small museum on the upper level of the baggage claim area.
Here is a photo of the plane:
http://www.airliners.net/photo/Hacienda ... 1091395/L/
Jaerl offline
Re: One Long Flight!
Yeah, a classic... I often think about it in regard to my O-300 when automatic rough starts to set in on cross country flights.
This was in a C172 I guess? I remember reading about a similar exploit back in the day, also behind a C-145/O-300, but it was in an Aeronca Sedan.
They had a barrel to use as a toilet and when it got full they would fly over to California and dump it out.
tcj offline
tcj
tcj wrote:They had a barrel to use as a toilet and when it got full they would fly over to California and dump it out.
Appropriate. LOL
Fisherman offline
I was just thinking of something clever to say about where the poop went.... and I scrolled down south to California. Guess I will just let the opportunity go this time.
flightlogic offline
6 postsPage 1 of 1
Users browsing this forum: No registered users and 29 guests
