OK, time for an update. Life, as always, seems to get complicated just when you were thinking you had some spare time
. In spite of a trip to Texas to get our old house ready for sale, and a trip to Alaska for some job interviews, there has been some progress.
Some things i have learned along the way for anyone else that might want to try taking on this small project:
Keeping the plane ready to fly was the right choice. Not only has it kept the pressure down on trying to get the work done as fast as possible so i could get back into the air, having it ready to fly has allowed me to meet the unanticipated twists and turns our lives have faced this spring. It has meant some repetitive disassembly/reassembly/disassembly, but in the long run, well worth it. It is very noisy, thank goodness for noise cancelling
After trying many chemicals, scrubbing platforms and techniques, i have found that MEK and paper towels are the cheapest and most efficient combination for removing the petrified baby diarrhea Cessna felt would be a great idea to paint all over the interior. They also work best for removing the adhesive sprayed/brushed over the petrified baby diarrhea. The best technique seems to be a spray bottle with MEK, spray dampen the paper towel and spray the surface to be cleaned, wipe till that area of the towel is saturated with petrified baby diarrhea and refold to a clean area, spray and repeat x 40-50 hours, piece of cake.
For adhesive applied to bare aluminum, 3M adhesive remover works best. Here a rag works best, dampen with adhesive remover and hold to surface for several minutes (because most of the adhesive is on the overhead
) Here is where you really want your beer handy so you have something productive to do while you wait.
Rigging a fan to circulate the air in the back of the plane while using the MEK, good idea. Even with a good mask, i think i lost a few more brain cells till i finally figures this out
SAS Safety 6605 Thickster Exam Grade Disposable Latex 14 Mil Gloves are the best! i went through LOTS of "chemical resistant" gloves, including some pretty pricey ones only to have them quickly fail after a few minutes of exposure to MEK, The Thicksters hold up great!
Over all, i'm glad i have taken this project, i have cleaned up a good bit of corrosion and it will be lighter and better looking in the end, But with a move back to Alaska in a month, the finished product is going to take longer than i anticipated.
The pile so far
27#'s lighter
So, now you know more than you ever wanted about Cessna interior renovation.
Chris
