Backcountry Pilot • Operating over square?
13 postsPage 1 of 1
O-470....what are the pros and cons in cruse and climb?
I don't run over square, but have been considering it.
I also use auto fuel and that could be a factor. The 91 octane I burn seems adequate?
Terry offline
Re: Operating over square?
Just fly it he way it feels the best to you and ballance that with fuel economy. And lean the heck out of it when at 65% and below.
Some of what I have heard on newer aircraft engines. I think yours is considered newer Terry. My overhaul company wanted over square for break in. They like their engines run hard every time you take off for the life of the engine. Full throttle even at sea level :shock:
Now my opinion as a gearhead my whole life. Aircraft engine 75% to TBO I will take it easier. Mogas on 90* plus days I will take it easier.
Good day
Operating over squared on take off is pretty common, and operating over squared with a turbo variant of the same motor is SOP. I suppose reasonable limits must apply, and some enigine / prop combinations have limitations of their own. For example MT doesn't want you to run beyond 2" over squared on the O-470, but the standard adage of 'don't ever run it over square' is generally something that 250 hr CFI's preach to new commercial pilot candidates because they have yet to understand for themselves the relationship between power and RPM. I suppose they'd shat themselves if they ever saw the MP / RPM in a big round motor :lol
Most engine builders will tell you on an O-470 break in, if you have any doubt what to do with the levers, shove them all fwd :shock: :lol: .
Some good reading:
http://www.avweb.com/news/airman/184483-1.html
YMMV, Rob
Rob offline
Isn't the concept of "squared" just a coincidental rule of thumb anyway? There's no real mathematical or engineering correlation between manifold pressure expressed in inches of mercury, and RPM in revs per minute. It just works out with our engines that the numbers and their units of measure align and appear to be power * 100 = rpm, and that happens to be a safe/effective setting. Easy to remember for boobs like me. :)
Is there a power chart available for the 470 showing the factory approved settings? The usual mention for cruise is 22,23,or 24 squared, or some slightly under-squared variation on this -- 21"/2300 seems popular. I don't know if this is by choice, or by necesity due to no more MP being available at altitude.
There is an excellent series of articles on the internet about operating engines. Google "Pelican's Perch, putting it all together". Very informative!
Hogy59 offline
MX-7-180B
A good landing you can walk away from. A great landing and the airplane is reuseable.
I love BCP but when you ask questions like this you open yourself to alot of speculation by non experts like me. The bes thing you can do is Google :D
http://www.avweb.com/news/pelican/182081-1.html
Glidergeek offline
Aircraft: 1968 P206C
DG 400
^^ Great article link Russ, thanks for posting!
Vick offline
Solum Volamus
http://dixiehigh.org/~gwhicker/index_files/1969%20Lycoming%20O-470%20Engine%20Manual.pdf
Of course, they've 'updated' certain areas since, but still interesting.....
lesuther offline
Rob wrote: 'don't ever run it over square' is generally something that 250 hr CFI's preach to new commercial pilot candidates because they have yet to understand for themselves the relationship between power and RPM. I suppose they'd shat themselves if they ever saw the MP / RPM in a big round motor
Haha isn't that true... along with every other fallacy in aviation :oops:
Right in your POH will be the charts for allowable power settings, and with the normally arpirated O-470 you can "oversquare" all day long.
Vick wrote:^^ Great article link Russ, thanks for posting!
Too much reading for me can you summarize for me Vic :D
Glidergeek offline
DG 400
13 postsPage 1 of 1
