Backcountry Pilot • Ouch my Back
Ouch my Back
23 postsPage 1 of 21, 2
Ouch my Back
Don't see this every day
http://www.dailymail.co.uk/news/article ... unway.html
Lucky he didn't break both legs and his pelvis. [-o<
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Re: Ouch my Back
Very lucky indeed. I suppose pilot preference is to blame here but the man appears to be wearing a chute but no helmet. I don't get that one. Aerobatic glider pilots please shed some light.
dirtstrip offline
Re: Ouch my Back
Parachute's required, helmet's not.
Pilot's option, in other words.
Look at all the motorcycles you see on the road. What's the percentage of riders wearing helmets?
Re: Ouch my Back
should be re-titled to say "Short landing contest winner". Talk about on the numbers.
670x offline
Re: Ouch my Back
Any other questions before you purchase a Swift S-1 Glider?
jjbaker offline
Re: Ouch my Back
Good thing the runway cushioned his fall :D Really, that is one lucky guy. What are the little things trailing his wingtips?
Jaerl offline
Re: Ouch my Back
The pictures have maid me a little confused.
It appears that the aircraft travels backwards as it crashes. The airplane ends up before the line on the runway, yet when it's above the runway it is after the line. Looks to me that it's the same runway marking in each picture.
Would some one explain to me what I am missing?
Thanks
Paul
Papa Victor offline
Re: Ouch my Back
XKV8R wrote:The pictures have maid me a little confused.
Thanks
Paul
I had missed all that until your comment. I suspect stall / spin set the whole event in progress.
Glidergeek offline
DG 400
Re: Ouch my Back
Glidergeek wrote:
I had missed all that until your comment. I suspect stall / spin set the whole event in progress.[/quote]
I suspect the same thing.
I still don't see how it could be traveling in that direction. I wish we could see a few pictures that were taken earlier in the crash sequence.
I figured somebody would say "it's simple,you missed this"
I would like to know what the deal is.
Papa Victor offline
Re: Ouch my Back
XKV8R wrote:I would like to know what the deal is.
Re: Ouch my Back
Thanks Z
I figured it was a steep turn stall.
Shouldn't the aircraft still be traveling forward? Am I the only one that finds this od?
I would think it would be traveling forward and sideways.
Thanks
Paul
Papa Victor offline
Re: Ouch my Back
Well it may not have had much forward horizontal momentum, and then when it hit, it may have...in a sense...bounced back. Or once it was sitting on the wheel the wreck caused it to roll back a bit.
Re: Ouch my Back
Well, think about what happens when a car switches ends in a skid, or a taildragger in a ground loop.
Go throw some sail plane models on the ground and see if you can replicate it. I don't think it's any aeronautical mystery, because the aircraft has stopped flying.
Re: Ouch my Back
It does seem pretty simple (but I could be wrong). Think of it this way... He is in a left turn with one vector of the turn perpendicular to the wings (think of g forces or angular acceleration). When he stalls, the wings lose lift and the glider moves in the direction of this force.
Think of Newton's first law: An object in motion tends to stay in motion unless acted upon by an opposite force. You have many forces involved here but the main ones are lift, momentum (or angular acceleration) and gravity. Lift is helping him turn, gravity is pulling him down and momentum is pushing him perpendicular to the turn (at least until the turn is completed and the forces are equalized). Lose the lift and gravity and momentum take over.
Thats how I would explain the fact that he traveled backwards.
Darinh offline
Darin H.
KOGD
Re: Ouch my Back
Probably his ass puckering so hard that it sucked the wreck backwards.
Re: Ouch my Back
I was going to suggest recoil from peeing his pants, but Gump's answer is better. =D>
Re: Ouch my Back
GumpAir wrote:Probably his ass puckering so hard that it sucked the wreck backwards.
Kinda like a Reverse Fart. Hell. I think I'll head home and scare myself some clean carpets.
Now where the heck did that cat get too?
GroundLooper offline
BCP Poser.
Re: Ouch my Back
It looks to me like he got quite a gust of wind right at the end of his downwind by the way the wings were rocking. When he turned base steeply the wind was pushing him backwards or in the downwind direction. He retained no forward momentum. So when he stalled and hit he was actually moving in the downwind direction which made him hit and slide backwards.
But, hey, what do I know!
Skystrider offline
Re: Ouch my Back
check out the youtube vid at the 29 second point: that sure looks like Captain Piccard from the Starship Enterprise! Dead ringer anyway. That glider did a great job of absorbing the impact sequentially, not many crashes you get to see the pilot like that, pretty amazing.
Re: Ouch my Back
Spoilers are out. Spoiled the lift as advertized. Lucky to crawl away indeed. I have seen 2 fatal glider stall spin accidents.
Skydive206 offline
