Backcountry Pilot • OWL STOL Kit Data?
OWL STOL Kit Data?
21 posts • Page 1 of 2 • 1, 2
OWL STOL Kit Data?
Does anyone know where I can find data for an OWL STOL Kit for a 206?
Akjetjoc offline
Aircraft: C-U206A PA-18
Re: OWL STOL Kit Data?
Akjetjoc wrote:Does anyone know where I can find data for an OWL STOL Kit for a 206?
Pretty sure the Owl kit was taken over by Horton.
Nothing very technical from "back in the day", but fun to read. My 182H got the Owl in 1969. They even put a stencil on the tail !ImageImageImageImageImageImage
Hman442 offline
Aircraft: Cessna 182H
I especially like the part where holding a spoon under a faucet shows you what the "Owl" can do !
Hman442 offline
I called Horton and they denied that they had any info on the owl.
Akjetjoc offline
I called Horton last year and asked about wingtip compatability with Owl leading edge. They said nope.
Hman442 offline
What data are you looking for ?
Hman442 offline
The stencil on the tail is cool looking [emoji41] [emoji1657]
Aryana offline
Aircraft: 1955 Cessna 170
Specifics on performance, weight, etc
Akjetjoc offline
My weight & balance states that my plane only gained six pounds when the Owl was installed. Seems light ? The brochures I posted are pretty complete - but absolutely no real data. In conversations through the years - the general consensus is that the Owl made the wing very similar to the new leading edge Cessna began using in 1973. and looking at the difference in the profile around the landing light opening, seems very similar to the Horton, but not quite as much difference. To me, it looks like the Horton extends a touch further, and has a bit more "lip".
Hman442 offline
Do you already have one of these kits installed, or are you considering installing one?
If you're considering a leading edge cuff, I wouldn't even consider installing anything except the Sportsman, even if the Owl kit was free. I know several folks who have removed Horton or Owl kits and installed Sportsman kits. And, never looked back.
Do you have this installed still? If so do you have Filler on your leading edge? I just removed mine and it had a TON of filler.
piperpainter offline
Aircraft: C-205
Was Backcountry Mooney M20C
This was after I removed the OWL
OWL S/STOL removed. The skin was a little over 6 lbs. but the filler and epoxy primer oyyy
Aircraft: C-205
The
Filler and epoxy primer…. I wish I could see the original STC installation paperwork….was this necessary!
Removed OWL skins
Aircraft: C-205
That's pretty atrocious Bryan, glad you're doing that and not me!
Maybe once you get all that filler peeled off you'll have a lighter airplane?
Halestorm offline
Aircraft: C-182E Pponk
piperpainter wrote:Do you have this installed still? If so do you have Filler on your leading edge? I just removed mine and it had a TON of filler.
Do you still have the paperwork on the OWL kit?
What is the STC number?
It's the SA995. I have looked and can't find the original install information. I have the STC paperwork, just not the install!
Aircraft: C-205
piperpainter wrote:It's the SA995. I have looked and can't find the original install information. I have the STC paperwork, just not the install!
Thanks. The full stc number is SA995SW.
FAA records show that stc as being held by Bob & Barbara Williams, of Bush STOL fame (or infamy).
Does your paperwork say it's an OWL kit?
I'm wondering if the Bush, Horton, & Owl stol kits aren't actually all the same stc-- just with different names.
Here is the STC
Here’s the STC. Sorry it’s the best I have on my phone
Aircraft: C-205
piperpainter wrote:Here is the STC
Thanks.
