Tue Aug 13, 2019 11:58 am
Yes, you could lose a few pounds by removing the electrical system. The question is: Do you really want to do so?
I owned a PA-11 with a -8 engine and it was in the mid eight hundred pound range, which left precious little useful load, with a 1220 gross weight. So, frankly, your airplane sounds about right, weight wise, considering you have an electrical system. The 1500 gross weight of the 18-95 offers more useful.
My 11 had a small battery to run the handheld radio.
Hand propping is an acquired taste, but don right it can be safe.
I might consider installing one of the new Earth X batteries, which are super light weight, remove the existing battery and box, then remove the alternator or generator, but leave the starter in place.
Around the home drome, you’ll still have a starter, just recharge the battery after each flight. Install a handheld radio, with external antenna, and a portable intercom.
You should be able to remove 25 to 35 pounds by doing that.
Take a good look around and see if there’s anything else that could be removed.
Finally, find out how it was weighed. Lots of mechanics just fill the fuel tanks, then weigh the plane, then deduct the factory listed weight of useable fuel from that weight to come up with empty weight. In fact, many of these fuel tanks actually hold a little more fuel than advertised. So, weighed with full fuel, hen subtracting listed useable fuel MAY wind up with a heavier than actual empty weight. It’s a say to get an extra gallon or two of fuel into some of these tanks,and it adds up.
Have it weighed with all fuel drained via gascolator in level flight attitude. You may find you gain some useful load. Maybe.
