Backcountry Pilot • Pacer left window
Pacer left window
7 postsPage 1 of 1
Pacer left window
Looking for a 337 from anyone that has installed a swing-out window in a PA22/PA20 on the left side. Looks like it would be super easy to add a frame, a Maule-style latch and gas strut for a real cool breezy window.
pilot offline
Aircraft: PA22/20-150
Former "Bushpacer" owner, joined the dark side and got a 182...
Re: Pacer left window
hotrod180 wrote:I'd check here http://www.shortwingpipers.org/forum/
Yep, and you would be in the very best place to check :)
I thought I would ask here too, ya just never know!!
pilot offline
Perhaps report back anything you find so that we can help the next Pacer-flying backcountry pilot. 8) We can even post copies of such 337 field approvals in our knowledge base under the Pacer entry.
Thanks.
The Clipper I owned for a few years had flip up windows on both sides. If I recall, Stewart Systems did the work and had the paperwork for it. I peaked at their website a little and could find it but it may worth a call to them?
Here's a pic. You can see the left window open in the background and in the foreground a little bit of the way it was installed:
It was a great mod and awesome to fly around with both windows open!
CW
clippwagon offline
I certainly will call them! Short of a left door, since my 22/20 has a new cover on her I think the opening window would be fairly simple, add little weight and certainly help with the boxed-in pilot syndrome :D
pilot offline
Also, you can sort of see it in the picture but the left window had one of those cirulcar vent cut outs that allowed some air flow when you twisted it open. That solved the all or nothing issue when you don't want the window wide open.
Good luck! I'm a big fan of the short wings!
CW
clippwagon offline
7 postsPage 1 of 1
