a64pilot wrote:As a general rule for most light aircraft, the flap setting that matches the number of degrees of deflection of an aileron at full deflection will be the flap setting that gives the most lift without excess drag.
So much for general rules because my 235 Maule's shortest T/O is with full flap IF I'm light and at low DA. The excess HP overcomes the excess drag![]()
The ONLY reason that I can come up with to not set the flaps prior to the T/O roll is that flaps being down may block some airflow over the tail and may delay it from flying just a little bit. As has been mentioned the drag from flaps at slow airspeed is negligable. If your aircraft "pops" into the air as you pull flaps, it would have wallowed off even sooner if the flaps had been there to begin with. Nothing dynamic happens from popping flaps that makes an airplane jump into the air, if it jumps into the air, you delayed flap application for too long. Unless you know your aircraft so well that you can tell exactly when to pop flaps, your better off setting them prior to the T/O roll or just after the tail starts flying, in my opinion.
You'll think I'm crazy, but when your practicing short T/O's cover or ignore the airspeed indicator and start trying to "feel" when she is ready to fly.
A64,
I have the same experience with my M-5-210-C. Lightly loaded...I can extend full flaps, push the yoke full forward and THEN add full power. The tail comes up almost immediately...count "one potato, two potato, three pototo"....rotate. Ignore the airspeed which may have just begun to indicate.
As soon as the mains leave the ground I level in ground effect and let the speed build just a tad. Remaining in ground effect I retract the flaps to 20 degrees accelerate some more, begin climbing, fully retract the flaps and accelerate to normal climb speed.
When I first tried this .....a couple of times when I rotated the tail just came back down on the runway as I was too slow to fly although there was full elevator authority. After a bit of practice I got it down to a science.
What a performer. I can lift off in 300 ft., keep the flaps down, start an immediate 360 degree turn, remain within a 500 ft. radius of the take off point, land and stop within the first 250 ft. of the runway....without ever indicating over 55 mph. And yes....the red stall warning light does flash. All this at light weight, near standard day conditions and a paved surface of course.
DON'T TRY THIS AT HOME!! "
Bob
