Lucky wrote:Looks good.
What type of paint are you using?
Is a two part from an auto paint store?
How about the color. I need to touch up a white spot on my wing. How did you match your color?
I don't have a sprayer setup, so I'm going to be using one of the preval sprayer setups.
thanks for you comments
Dale
Lucky wrote:Jim,
Thanks for your tips and how are you cleaning before spraying. Alcohol & then a clean rag wipe?
jaudette wrote:I like acrylic enamel. Take one of your inspection panels down to a higher end auto-paint store and have it matched. Go to harbor freight and pick up one of their all in one airbrush kits. Has the compressor and every thing you need. Pick up some thinner to clean the brush.
Jim
colopilot wrote:Jim, do you know anyone out here good with more than touch-up level paint work? I have a LOT to do (wing leading edges and other areas, cuffs, rudder, fin, tips, belly, etc). It may almost be worth stripping and starting over by the time I put all these new parts on there, but would like a professional opinion.
