Backcountry Pilot • Painting Cabin Floor in 206
2 postsPage 1 of 1
Hi,
I was looking at the cabin floor in a U206G Soloy that I bought as a project. It seems to be painted with a wingwalk type paint, with very little grit, almost as if they mixed wingwalk with regular black paint. It's done really neatly and looks a decent job. On my U206F the floor is just green primer. I need to paint the recessed footwells in black as the SCS Vinyl Kit does not cover these areas.
Seeing the whole floor painted on the U206G got me thinking should I try do the same job? Paint it all over with a brush on paint? Maybe I should just use aerosol 2k black on the footwells and little bits where the SCS Vinyl doesn't cover?
irishc180 offline
Re: Painting Cabin Floor in 206
You could use a rattle can black on the floor however you'd have a half a day of masking to perform first. Overspray doesn't come off polycarbonate windows easily. Brushing and tipping would work fine. That is roll it on with a small roller, and lightly brush out any lines with a quality brush. Your paint choices could be anything from Rustoleum to Allgrip. Rustoleum might be good enough for what your trying to accomplish.
On The Fly offline
Aircraft: C`182K
2 postsPage 1 of 1
