Backcountry Pilot • Panel Shock Mounts
Panel Shock Mounts
11 postsPage 1 of 1
Panel Shock Mounts
I need to replace the instrument panel shock mounts in my '56 C172. The ones stocked by Spruce and a number of other suppliers have steel studs instead of brass. Has anyone used these shock mounts with steel studs and if so did you have any issues with your compass?
Thanks.
Frank
fshaw offline
Re: Panel Shock Mounts
Fshaw
Try Chief aircraft supply - they have steel AND BRASS
http://www.chiefaircraft.com/aircraft/i ... ounts.html
Chris C
wannabe offline
53 C-170-B+
It's not a problem to find the brass, but shock mounts with steel threads can be had for less that half the price. I've read on another site that quite a few people are using the mounts with steel threads. I was wondering whether anyone here had any first hand experience with them as related to compass issues.
Thanks.
Frank
fshaw offline
exact brass replacements from an auto hardware company. when I get out in the hangar I will post the info. If I remember correctly they were only a few dollars a piece.
cliff offline
Aircraft: Cessna 180
Aeronca L-16 Cessna 150 Kolb KXP
McMaster-Carr part # 9376k17 vibration damping sandwich mount, male/male, 8-32 thread, 1/2" H, 5/8" W, Natural rubber . Less than 2 bucks each.
cliff offline
I put the aircraft spruce steel stud shock mounts into my 57 C-172, no problems with the compass at all.
Dale Moul offline
Dale
Gravity Strikes Again.
x2
slowhawk offline
Do you guys feel these shock mounts are really necessary? I had a couple damaged and/or badly sagging ones on my last airplane-- I just replaced all of them with stainless machine screws & aluminum spacers. Didn't notice any difference in how the instruments worked or held up.
My current airplane has 10 or 12 shock mounts holding the panel on. They are starting to sag, no big deal except that now the panel is a little too close to the pull switches below. $65-70 for replacement shock mounts from Spruce, but I've thought about going the machine screw / spacer route again.
Thoughts?
Exact replacement from McMaster- Carr less than 2 bucks a peice. Just did mine in July. EXACT!! brass and all.
cliff offline
hotrod180 wrote:Do you guys feel these shock mounts are really necessary? I had a couple damaged and/or badly sagging ones on my last airplane
Thoughts?
No I don't, but when I re-did my panel, the AI I had overseeing my work decided to go back with the shock mounts. I also had to use the same size 1/4" aluminum stock for the panel, his concern was that it was "structural", which I found odd since it used the shock mounts. Bet I could have used a much thinner material and been fine, but his signature was on the line
slowhawk offline
Cliff you are the man. Just ordered a set from McMaster-Carr. I'd looked at their mounts but missed the ones with the brass threads.
Thanks very much.
Frank
fshaw offline
11 postsPage 1 of 1
