Parts interchange between 100 series cessna?
Hi guys,
Is anyone familiar with the precedent for replacing parts on a 182, but from one donor model to another?
I happen to know of a horizontal stabilizer from a newer 182 that I could get a really good deal on. It's the newer, wider, stabilizer so I'm very interested.
Thanks
CParker offline
487
- Aircraft: 1979 TU206G
Tue Jun 16, 2020 11:17 am
If you are replacing the same p/n from one plane to another that's easy. If they are different parts, then you need to make a minor/major determination as this is an alteration. If major, like your proposed horiz. stab, you will need to find an STC or ask the FSDO how they feel about a field approval. For the latter, if you could find a copy of someone else's 337 that would be helpful.
C180_guy offline
488
Tue Jun 16, 2020 12:05 pm
CParker wrote:Hi guys,
Thanks
I'm assuming it comes with the elevators as well?
5186
Yes, it's a complete airframe
CParker offline
487
Talk to Cessna about parts substitution. Not uncommon Fo them to provide a letter of approval. Makes the process a lot easier. A tremendous amount of parts are from the 182T are still a perfect fit for older models. Cessna has also been good about providing cross-reference part numbers from older to new.
nordicdave offline
21
- Aircraft: Cessna 182P w/Rajay Twin Turbo & Robertson STOL kit
