Passenger in cargo area.
Can a person legally ride in the cargo area with no seat or seat belt? Thanks
6977
Not unless they're wearing a parachute (as in a skydiving gig), or proper retention harness, as in aerial photography.
10514
6977
Even as a skydiver, videographer they still need to be belted.
Bdiazair offline
214
keep them flying!
Rob, even if you didn't get the 5th seat base option in your Maule, the seatbelt mount points are there.
Passenger does not need the seat, just the seatbelt. I argued that one with the Fairbanks AK gado or fisdo or whatever it was called in the late '70s, and won the discussion.
If not using the #3 and #4 seats you can use one of those belts at the #5 seat area position.
maules.com offline
561
Of course, this brings up the question, how do you determine which loves you more, your wife or your dog?
Answer (aviation oriented): stuff each of them in the baggage compartment of the airplane for 30 minutes, and see which one is glad to see you at the end of the time.
3801
OregonMaule wrote:Can a person legally ride in the cargo area with no seat or seat belt? Thanks
The one exception is when they are in a casket...
2339
- Aircraft: C180H / C170B
www.avthreads.com
Bigrenna wrote:OregonMaule wrote:Can a person legally ride in the cargo area with no seat or seat belt? Thanks
Thread drift alert, but determining the W&B of a casket was part of my PP check ride. Anyone have a guess as to the process?
Hammer offline
2094
Hammer wrote:Bigrenna wrote:OregonMaule wrote:Can a person legally ride in the cargo area with no seat or seat belt? Thanks
Is there are special "casket station" for the moment arm? Or must you compute the centroid of the casket?
2854
What kind of sick-o carries a casket in their airplane anyway?
Seriously though...you balance the casket on a sawhorse and mark the point of balance. (I assume you use a piece of removable masking tape, not a permanent marker.) When you put the casket in the airplane, calculate 100% of the casket weight at the station of the point of balance.
Always thought that was a neat trick.
Hammer offline
2094
Hammer wrote:What kind of sick-o carries a casket in their airplane anyway?
You had a DPE with a very macabre sense of humor!
3801
Cary wrote:Hammer wrote:What kind of sick-o carries a casket in their airplane anyway?
Sounds like he was trying to trip you up and see if you were savy enough to run a second W&B in the event he transformed into a bat mid-flight.... some of those dpe's can really suck the life out of you..
CFOT offline
581
Carried them all the time in bush Alaska.
I divided the weight by the length at each seat row station that it replaced.
akaviator offline
512
- Aircraft: Cessna 180
