Of coarse I'm not sure of the exact details. But wouldn't it make more since to send a slower, smaller, non-jet aircraft to check on the Cirrus? I'm sure there had to have been a turbo prop (like a King-Air) or small jet (like a "Slowtation"). But then again, maybe not at that moment.EZFlap wrote:The airline crew can argue that they maintained a far greater distance from the Cirrus than the distance ATC has them separated (on short final) from other airliners who are waiting to take off. Here at Los Angeles International airport, we will have pairs of airliners 500 feet horizontally apart barreling down parallel ILS approaches... about 200 times a day.
Suspending the pilots and controllers in this case is absolute chicken shit.
Bonanza Man wrote:
500 feet horizontal? I don't think so. Better measure again with Google Earth. No airport anywhere is running parallel simuls 500 feet apart. Minimum separation is 1.5 miles diagonally if the runways are at least 2500 feet apart. If the runways are any closer together standard separation(3-6 miles) must be used.
Grassstrippilot wrote:So yeah, approaches that close between aircraft do happen in visual conditions. I'm guessing the separation numbers you wrote down were for actual instrument conditions in IMC.
Hmmm...better check those numbers again Bonanza
Rooster Cogburn wrote:http://www.dallasnews.com/business/headlines/20110330-faa-controller-southwest-airlines-pilots-suspended-after-flying-too-close-to-another-airplane.ece
lowflybye wrote:Grassstrippilot wrote:So yeah, approaches that close between aircraft do happen in visual conditions. I'm guessing the separation numbers you wrote down were for actual instrument conditions in IMC.
Pretty sure they can run parallell simultatanious approaches in IMC provided both aircraft on operating on the ILS approach...if the ball is centered the seperation is the same.
