Backcountry Pilot • Poll: Certified or experimental
24 postsPage 1 of 21, 2
For aircraft you own, which airworthiness certificate ?
Standard airworthiness - aka Certified/Normal/etc
124
57%
Special airworthiness - Experimental amateur-built
46
21%
I built/am building my experimental amateur-built aircraft myself
46
21%
Total votes : 216
Hi everyone, I'm just trying to grab a snapshot of our community cross-section for who owns certified vs experimental or both.
Please answer the poll. You can answer both choices if you own both. Or all three. They are not mutually exclusive.
You can respond if you like, but I mainly need the data of the poll answers for a percentage breakdown.
If you're using Tapatalk, try this link to open the web version: https://goo.gl/6ZvgSA
Thanks!
Re: Poll: Certified or experimental
Well darn... I have both. Cessna and an RV-7
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
I am the odd man I guess since I checked all three. Cessna, RANS, and a project (Murphy Rebl that's on hold).
Both. Carboncub EX and 1/3rd of a PA12
Sent from my SM-G930V using Tapatalk
C130jake offline
Bushmaster 250 XP home built
ghan offline
Aircraft: Bushmaster 250 XP
Homebuilt
I am a fan of certified but I also like a well built experimental.
Bdiazair offline
keep them flying!
If you have both, then check both boxes. The poll is designed to allow all three checked.
I guess Tapatalk doesn’t show the poll?
I have a certified fwiw
Sierra Victor offline
Aircraft: Cessna T206H
Sierra Victor wrote:I guess Tapatalk doesn’t show the poll?
yeah, Tapatalk sucks.
Will u check the “certified” box please?
You can tick "web view" in the upper right hand corner to take you to the desktop version of the poll where you can check it yourself.
Halestorm offline
Aircraft: C-182E Pponk
I have a Cessna and a Bearhawk. I hope to have one airplane soon..... translation: flying Bearhawk!
akschu offline
Contributing author
Aircraft: 1949 C-170
20?? 4 place Bearhawk
Thanks for the poll responses everyone.
Tapatalk doesn't give you full site features.
I can't vote even with the link you gave us. But I have a certified plane, and a certified project. You didn't have that as an answer I know, but it should count just as much as an experimental project...
May have missed the vote, but I bought an E-AB
Stinson 108-1. Flown mostly in the utility category. I'm a fan of the CAR3 stuff.
Stinsonaut offline
Aircraft: Stinson 108-1
Not to make too fine a point of it but my new to me S7 is none of the above. SLSA. Not amateur built. Experimental flying Light Sport. Factory built etc. I put myself in as experimental amateur built.
Mister701 offline
Aircraft: Rans S7LS
Ditto the above. S-LSA converted to E-LSA doesn't really fit any of them.
WYflyer offline
Both here. Maule and RV
shortBuzz offline
Aircraft: Maule M5 & RV6
Building an experimental Bearhawk..busted the certified Pacer...fuselage done...wings under construction.
m_moyle offline
Aircraft: Piper PA 20
