Backcountry Pilot • Possible to zero out a Hobbs?
20 postsPage 1 of 1
Key got left on after I did some wiring work in my experimental project and ran up 26 hours on my brand new hobbs. Any way to zero them back out or I am stuck doing math all the time? It's just standard Honeywell Hobbs but could not find anything using Google.
AvidFlyer offline
You can take it apart and set it where you want or they are not that expensive.
a64pilot offline
Hour Meters and Controls
[email protected]
(phone #217-753-7773)
ask her maybe she can answer it. Some of the untits are sealed. Might hafta get a new one or deal with it being off the 26 hrs.
Jeff
Jeffrey Flinn offline
I would think you would want to wire your hobbs to your oil pressure sensor so it would only work when the engine was running?
Terry offline
bcpstudent wrote:I would think you would want to wire your hobbs to your oil pressure sensor so it would only work when the engine was running?
I'm thinking it might be something that doesn't have any oil pressure
a64pilot offline
What difference does it make? Most mechanics go by TACH time, not Hobbs time, when it comes to maintenance requirements, which generally saves you some $$ anyway. You do have a tach??
True enough.
Talking about an experimental here.. two stroke Rotax.. no oil pressure, simple tach with no time, I'm the mechanic, ect, ect. I just thought it might be as simple as it was to calibrate my altimeter. I'll either suck it up or spend the $50 for a new one. Doesn't get much simplier than this
AvidFlyer offline
Unplug it for the next 24 hours and keep a log with your watch.
Baddog offline
If you find yourself in a hole, the first thing to do is stop digging.
Baddog wrote:Unplug it for the next 24 hours and keep a log with your watch.
Now you're talking. Good practical advice!
tom
Savannah-Tom offline
Thats a cheap way to fly off that initial 40 hrs :wink:
m7flyer offline
Your Garmin has a flight log use that for next 24 hours.
Green Hornet offline
AKA SOJORRN
1997 Maule-M7-235C
I am a leaf on the wind watch how I soar! Hoban "Wash" Washburne, Firefly/Serenity
WOC SPOT
Not sure if it will run backwards but have you tried wiring it backwards and see if it will run in reverse?
Keith
You could also wire in an airflow activated microswitch that would only log time when you were in forward flight.
Kenny Chapman offline
WWhunter wrote:Not sure if it will run backwards but have you tried wiring it backwards and see if it will run in reverse?
Keith
It won't, I tried it with a 9V battery, reverse the polarity and it didn't do anything. I assume it has a diode in it? I'm looking at one on my desk, to get into it, you would have to pry off the edges of the metal cover. I doubt you could get it back together and it look right. Best plan is to fly the first 26 hours with it disconnected and then plug it back in as suggested earlier.
a64pilot offline
Kenny Chapman wrote:You could also wire in an airflow activated microswitch that would only log time when you were in forward flight.
Then maybe if I flew backwards the time would count off????? :shock:
AvidFlyer offline
I think unplugging it for 24 hours of flight is the best advice. They are made so that you can't tamper with them without destroying them. Be careful asking certified guys about experimental aircraft, you will almost always get the wrong advice. Almost.
Try these guys: http://www.homebuiltairplanes.com/forums/
svanarts offline
Re: Possible to zero out a Hobbs?
AvidFlyer wrote:Key got left on after I did some wiring work in my experimental project and ran up 26 hours on my brand new hobbs. Any way to zero them back out or I am stuck doing math all the time? It's just standard Honeywell Hobbs but could not find anything using Google.
I don't know how your wiring is set up, but it should be possible to pull power for your hobbs directly from the lighting coil on your rotax. This would then only clock time when the engine is running. Depending on the type of Hobbs meter you have you may need to add an inexpensive rectifier. There is some good information on wiring hobbs meters in the CPS catalog. I know a guy that left his battery switch on and ran over 200hrs on the meter :shock: . Kinda hurts the resell value on a two stroker.
Nick
Swingwing offline
1974 Cessna 172M
Rotorway Exec 90
About a hundred years ago when I was in High school, I dated a girl who drove a Corvair. Her dad would check the mileage all the time so when she ran around and used up more than she was supposed to she would go around in circles in reverse in the parking lot until she had run off the extra miles.
Made her dizzy as hell but it was fun to watch.
Try that, put her in a tight turn going backwards and watch the time run off. :twisted:
shorton offline
Aircraft: Stinson 108-2
give it to someone that has a pusher for the next 20ish hrs, know anyone with a velocity? :shock:
soaringhiggy offline
48 Stinson 108-3
20 postsPage 1 of 1
