Just read MOST of another Ppnked 18x with no reported problems.
Seems to my limited vision that the other X-over tube appeared to be a bit smaller in diameter. To tired to go back for comparison again. Sorry. CC
DENNY wrote:Dan
I have spent enough money on engines to understand that there is a point where a proper gauge will more than pay for itself. If nothing else it tells you what is working so you can move on. Get a proper 6 cylinder EGT/CHT and see what cylinder is causing the problem (or not) and go from there.
DENNY
john54724 wrote:Speak to the Man himself and he will tell you to use the smallest diameter balance tube and no need for insulation. The smaller one provides best protection from icing and more room for governor.
Ace007 wrote:Engine builder was Aero Engines of Winchester VA. They put the front seal in wrong, didn't tighten *at all* the oil adapter, and had multiple induction leaks. Hope that was all they screwed up.
