Pre-heaters cannot be found south of the Mason-Dixon line?
Im flying my 182 back to Colorado from the Bahamas and a spent the night at an airport in Alabama last night. Slept out in a tent (15 degrees) and awoke to find my water bottle next to me was frozen. To my surprise, no one I've asked at any of the airports of stopped at has a pre-heater, nor do any of the fbo's. I spent the morning with my cowling off, sitting in the sun, trying to get any warmth to it. Ended up hitch hiking a ride with a police officer to a hardware store and bought a propane space heater that was able to get enough heat on it to start up.
Anyone have that link to the back country diy pre heater? Or any other recommendations for someone in this predicament? Got off 4 hours behind schedule today and had to park it for the night again in Arkansas. No pre-heater at the fbo and all the heated hangers are full... we will see tomorrow...
ington6 offline
396
- Aircraft: C185
C90 Cub
Blanket over the cowl and a 100 watt bulb inside, hair dryer. Point in the cowl flap over night will work also! Set it on something so that if it melts it will be out of the cowl, as long as it is cold it should work.
GT.
M6RV6 offline
2313
- FindMeSpot URL: http://share.findmespot.com/shared/face ... sWKXuhKlg2
An el-cheapo small electric heater works too. Stuff it in the bottom of the cowling, and wrap things with a sleeping bag or thick blanket. Just don't aim it at anything plastic. An hour or two should have crank and oil toasty at those temps. Just watch it so you don't melt anything.
4557
- Aircraft: Old Clunker
Our flying club has a PA12 on skis and has always used a small electric heater like Gump mentioned (8 inches or less in length) and a cowling blanket. The temperatures up here, are colder than what you are likely to encounter, but it has always worked great. A very cheap solution if you have electricity. Steve
steve offline
822
- Aircraft: 1980 Cessna 185F
Carry a cheap 1200 Watt hair dryer with you since you are landing at airports rather than back country strips with no electricity readily available.
obxbushpilot offline
240
- Aircraft: C 172 Tailwheel
