BCP community,
I am considering purchasing a propeller balancer for my personal use. Does anyone have a recommendation on make and model for a decent system that won’t break the bank?
Thanks for any input.
gbflyer wrote:I just spoke with my dad about this.
Our little consortium (OK really little...2 airplanes) owns a PB3 balancer. It's hard to use but does work. Directions are written for those who are technically very saavy which makes it difficult for us hard heads. Viking Aircraft Engines will rent you a Dynavibe for $130 a week. It's a much more refined process as I understand it.
I don't think you asked about the legality of it. For what it's worth we use ours on our E-AB aircraft. No idea what paperwork is involved with real airplanes.
Oh yeah, forgot to add that we were already in the green zone without adding any weight and we still have a rough spot at the mid 3000 rpm range. Money well spent. [emoji15]
Halestorm wrote:gbflyer wrote:I just spoke with my dad about this.
Drift Alert!
3000 rpm, this is a geared engine? I would be more suspicious of an engine problem, ignition or reciprocating mass. Prop balances typically are done for just one rpm (cruise) and don’t really fix rough spots in my experience.
YMMV
mtv wrote:You could pay someone to balance props for you a number of times for the price of a good machine. I’m sure you realize that.
But, the question in my mind is, what will you do with the data you derive from CHECKING the balance of your prop? If you then add balance weights to a prop, are you not performing “maintenance”, which requires a logbook entry signed by a mechanic?
I don’t know the answer to that question....but it’s one I’d want the answer to.
I’d also want to make darn sure I got some REALLY good training on how to use the thing.
I’ve watched a mechanic who really knew what he was doing fiddle with prop balance on one plane, and couldn’t get things to come together. Gave up.
FWIW
Kiteguy wrote:.... I balance once a year because it always has measurably changed by then. ....
