Regarding your intent to replace your windshield mag compass for a panel mounted vertical, I would STRONGLY recommend NOT!
I have a vertical card that the previous owner of my 185 installed on the glare-shield and it is the most almost worthless piece of junk. It has been serviced and checked and still is erroneous often. It almost sent me way off course when flying through Northern Canada. If I would have continued, it would of probably been a crash in uninhabited wilderness. I intend to remove it soon and replace it with an Airpath hanging from the windshield where it belongs away from magnetic fields from panel mounted equipment. I have much more confidence with the OEM type set up when flying in the bush. Every Boeing I've ever flown has had the mag compass mounted high above and I think that is for good reason. - Your results may vary and if you're not going to seriously fly your airplane in the bush it might not matter.....FYI-my experience only.
