Has anyone installed a pulselite module or Avtek Pulsar to have their landing light flash for visibility? Looking at both systems and looking for input from those that have them.
Thanks,
Travis
Cary wrote:I have the Pulselite system on my P172D, flashing both the landing and taxi light at the same time (since they're side by side in the left wing, having them alternate would make them appear to be steady on all the time). I have HID lights, so it's recommended that I first turn them both on with the main switch, then turn on the Pulselite switch, wait 15 seconds for the power supplies to warm up, then shut off the main switch, which starts the pulsing.
They're slightly annoying at night, especially if there's a little haze in the air, but I feel safer using them night or day. I typically turn them on within 10 miles of any airport, and I turn them on if ATC advises of conflicting traffic. Others have reported that they make my airplane a lot more visible.
bumper wrote:I have a PreciseFlight Pulselight in two aircraft. Reliable, works well and less expensive than the Avtek. Frankly, I wouldn't do business with Avtek after the crap they sold for emergency standby power for GA.
That said, I wouldn't buy either at this point, as wig-wag function is included in some of the newer LED landing/taxi lights, check out AeroLeds stuff. Top rated by Aviation Consumer and amazingly bright. I replaced 4 landing and taxi lights on my Husky. With a projected lifespan of 50,000 hours, I leave them on wig-wag for all daytime flying.
Prior to this purchase, I did a comparison of the Q4509, a 55 watt HID, and the AeroLED 36HX on my hangar door. Both the HID and 36HX handily beat the quartz halogen in terms of light output. The 36HX was as bright as the HID, but the beam evenness and quality was better than the HID.
The LEDs have another major advantage over incandescent and HID, and that is in their very fast switching or rise time. This makes the lights more noticable in someone's peripheral vision.
bumper wrote:Yes, you can turn off the AeroLed wig-wag function and use the LEDs on steady. You can also use the flash or wig-wag fuction to flash a single or pair of lights if you don't have lights on each wing to allow effective wig-wag.
I have a PulseLight in my Husky, so did not get the AeroLed model with wig-wag. There's a landing light and taxi light on each wing. I wired them using diode isolators so that when the landing light switch is on, both taxi and landing lights come on steady(all four lights). When taxi lights are selected on steady, only the taxi lights come on (the taxi lights are wider beam and declinated so they don't blind other aircraft while taxiing. And finally, in pulse light mode all four lights wig-wag, landing and taxi on one wing come on together, then opposite wing. Looks like an emergency vehicle even in broad daylight.
29singlespeed wrote:
Thanks! Email sent to AeroLED to see if they have an option for the old 182. Can't tell from their site, seems to be mainly experimental focused.
Looks like they have one Certified bulb. 1000 lumen, $450 each. Thanks Bumper, I was looking for a bulb like this, the pulselight kit is cheaper, but this is much easier to install when I've only got 1 light on the Citabria. I'd like to add wing recognition lights that wigwag but haven't found a kit like that.
http://store.aeroleds.com/index.php?mai ... ucts_id=44
SixTwoLeemer wrote:
Check out the Alphabeam...highest rated Taxi/Landing LED...much cheaper too.
http://www.aircraftspruce.com/catalog/e ... glight.php
hotrod150 wrote:A buddy of mine bought a Maxpulse flasher for the Pacer project he's working on. Not flying yet, but it looked like a slick arrangement-- you can set the thing to flash the two lights in several different ways. Don't recall the price but it seemed pretty affordable.
