Push-Pull Cub
Interesting looking design-- looks like you could stand that one on it's nose & as long as it didn't go all the way over you wouldn't hurt anything too bad.. I don't know about the high thrust-line though-- application of power would drop the nose instead of raising it, might take some getting used to & even then might not be a good thing.
I can't tell from the photo but from the thread title this is an inline twin? I wonder if a plain old pusher might be better than a push-me/pull-you with the same total hp.
10534
Sat Feb 18, 2012 12:16 pm
It is an inline twin. The rear engine is hidden by the wing in the picture. Power effects will certainly be there, but the level would have to be tested I guess. I do like that orange though.
soggyc offline
129
- FindMeSpot URL: http://share.findmespot.com/shared/face ... KhvYFzCT8z
i have ruined 6 Warp drive prop blades on an aircam going from mud to gravel during the takeoff roll with 29" ABW's. i don't think a pusher is a good bush plane.
Blake offline
7
Sun Feb 19, 2012 11:57 pm
Wow... might want to look into mounting some sort of mud guard or plastic ATV fenders on that AirCam ??.
2226
...it has gone through quite a few more mods since it first came out.
What are those spears attached to the wing struts?
tcj offline
1278
tcj
Yes the "Double Ender" as Alec calls it is an ever changing project.... just wait these guys have some cool ider's.....
Hottshot offline
710
tcj wrote:..What are those spears attached to the wing struts?
I don't know, but they're barbed so it must not be catch & release.
Seriously (ha! fat chance) maybe they're pitot tubes for accurate airspeed readings in undisturbed air?
10534
hotrod150 wrote:tcj wrote:..What are those spears attached to the wing struts?
It was an airspeed boom and a alpha/beta boom.
soggyc offline
129
Tue Feb 21, 2012 11:10 am
OK, I'll bite-- what's alpha-beta? (and don't tell me it's a grocery store chain!)
10534
Tue Feb 21, 2012 11:40 am
Alpha is angle of attack (in pitch axis), Beta would be the angle of "attack" in the yaw axis.
When you hear test pilots and engineers talking about "high alpha", that means flight at high angles of attack.
2226
It is 2016. Anyone know where the development stands re the DoubleEnder? I recall reading somewhere of a possible 2016 introduction?
Denali offline
809
Fri Mar 23, 2018 11:36 am
Z:
Was wondering if you have had a recent update on the Doubleender?
Regards, L
88H offline
312
88H wrote:Z:
Regards, L
I don't, just that Alec and crew are working on their side-by-side design. I texted with him briefly today and he said they're close to test flying.
2855
Thanks! Was hoping that the Doubleender was about to be available. Wonder why they paused on its development?
L
88H offline
312
I found the DE an interesting exercise in thinking outside the box, but I wouldn't want one. Double the engine maintenance obviously, is forced to swing a (well, two) small dia. props) and there is no getting around the high thrust angle issues. KISS.
4197
