Backcountry Pilot • Question for Airglas Fork experts
13 postsPage 1 of 1
Here is a picture of the nose fork on my 182, is this the kind that needs to be cut shorter to add the big wheel fork conversion?
Hoeschen offline
Aircraft: 1956 C182, 2014 RV-9A
Re: Question for Airglas Fork experts
It'll depend on the year of your airplane. I had to cut 2" off the nose gear of my '56 182, but that was the tallest 182 gear Cessna made. IIRC the Airglas STC contemplates trimming the nose gear as needed, so no additional approval needed.
48RagwingPilot offline
Yes you will need to trim that for sure.
PAMR MX offline
How big are you going on the mains? What size nose wheel?
DENNY offline
DENNY
This is my 1956 182, but my nose gear doesn't look like the original 56 nose gear which always looked so tall and lanky. Near as I can tell though it looks like the type that Airglas says needs to be chopped. Not a big deal but wonder if it can be done without removing?
I'm definitely not going 8.50s all around. Maybe 8s on the mains and 7 up front at the most.
Hoeschen offline
That Knisely exhaust in the background with 125 hrs on it will be for sale as soon as I finish my seaplanes west engine mount upgrade. The shroud is pilot side exit, as was stock in 1956.
Hoeschen offline
Hoeschen wrote:That Knisely exhaust in the background with 125 hrs on it will be for sale as soon as I finish my seaplanes west engine mount upgrade. The shroud is pilot side exit, as was stock in 1956.
Why don't you just get a new heat shroud?
I've been looking at the knisely exhaust, is there another reason you're getting rid of it?
Halestorm offline
Aircraft: C-182E Pponk
Stock exhaust doesn't fit with seaplanes west mount. The frame of the seaplanes west mount sits lower (because of the fat lord mounts I presume) and the stock 22" wide muffler is a few inches too wide to fit between the frame. So I had to buy a newer style muffler which is narrower and compatible with the mount (a few thousand dollar surprise). I went with Acorn welding. Not sure what year changed to the narrower muffler...
Hoeschen offline
I have done them on the airplane but it's a pretty good time to install a new seal kit on the strut and service with new fluid and some STP. You can also install an intake hose on the strut for a run flat bumper at this time but I suppose you could do that with just the bottom end off.
PAMR MX offline
Hoeschen wrote:Here is a picture of the nose fork on my 182, is this the kind that needs to be cut shorter to add the big wheel fork conversion?
THIS IS NOT A 1956 NOSE STRUT !!!! It's a 57 or later already shorter ! Don't cut anything !
182 STOL driver offline
Thanks! That's kinda what I suspected. Can always cut later.... Hard to add back!
Hoeschen offline
You will want to cut it .750-1.00 below where your tow bar is attached , the lower mount for the travel limiter (not sure of proper name) is machined into the airglass block that bolts to block and strut
I just installed a big fork on my 1960 182c
You will see there is only one bolt on strut not two, like original.one holding travel limiter and one holding original fork
Airglass is made to be like the later models
Zoom in and hopefully these help
Slantbuggy offline
You will need to cut. Here is some docs that come with the kit. Forget about the year it's all about configuration.
PAMR MX offline
13 postsPage 1 of 1
