Joey,
*Important*
Menu>Menu>Location>Location Format...
Verify the location format your 196 is set up in is the same as the format for your coordinates. If not your coordinates wont get anywhere near where you want to be. Also what source are you using for you coordinates? The reason I am asking is because some sources just don't carry a particular format out as far. For example if your garmin formatted as hddd°mm'ss.s" it lists 7 characters, the corresponding format for google earth is Degrees, Minutes, Seconds and it goes out to 8 Characters. The only 9 digit format on a Garmin I can think of is hddd°mm.mmm, but it is still important to verify that, that is in fact the format of your coordinates.
Hope this helps, feel free to pm me if it sounded too confusing.
Take care, Rob
Rob on Sat Jun 19, 2010 10:06 am, edited 1 time in total.
