Glidergeek wrote:....... and I think they use longer fingers.
58Skylane wrote:Glidergeek wrote:....... and I think they use longer fingers.
and what do you figure they use them fingers for?
Glidergeek wrote:58Skylane wrote:Glidergeek wrote:....... and I think they use longer fingers.
Deeper prodding and probing. Why do you think those airline pilots skip the TSA lines, they've had enough
mtv wrote:John,
As long as you are UNDER 40 years of age, there are NO medical requirement differences between the first and second class medical. Over 40, the first gets a lot more expensive, because of the requirement for an EKG.
once&futr_alaskaflyer wrote:http://www.faa.gov/about/office_org/headquarters_offices/avs/offices/aam/ame/guide/standards/
As noted by another poster above, unless going through the special issuance process, for second class you must be correctable to 20/20 in BOTH eyes for distance vision. For third class you can be up to 20/40 in each eye.
Also for second class they check your intermediate vision (20/40) they don't in third class.
robertc wrote:Yes, but you have to demonstrate to a Fed you can pass a light gun test.
