The RAGE which is also known as the Roberts Air Gear Extreme, uses a light-weight modern racing shock similar to ones being used by snow machines and utv’s to bring the world of taildraggers into the 21st century. Imagine the bone-jarring, head rattling feeling from a rough field, rocks, etc., or the rebound into the air from a dropped in landing. At this point you might feel like you are going to break something on the airplane or even yourself. This is just the way it is, the way it has always been. Now imagine riding along and wondering if the ground is a lot smoother than it looks, seeing the same bump ahead and preparing to get rocked and rolling over it with without even being able to feel it in the cockpit. It’s real. The following video is the reaction of a pilot who got to test it out for himself.
You see, the problem all current options for suspension have is that they are based on the expansion and or compression of steel springs or elastic material to perform this job. The big problem with bungee or spring systems is that the return or recovery rate is very fast and has a rubber band or slingshot effect. The problem with compressed rubber wafers is just the opposite, sometimes the recovery is too slow or even worse the compression reaches its max and thus turns into a solid rather than continuing to work. Not one of these systems is easily adjustable. The RAGE is.
The RAGE is infinitely adjustable. I’ll go you one better, it’s cockpit adjustable! Imagine you are sitting at a backcountry landing strip or just some flat spot in the boonies. You unpack your camp and get settled in. When you flew in you had the suspension set to haul the weight of your gear as well as a buddy. Now you’d like to do some solo flying and check out a few spots. Well, you don’t have the extra weight anymore so soften up the suspension a bit with the cockpit adjustment system and head out. When it’s time to go home you can pump the suspension back up and load the plane. You just can’t do that with current systems. You can with the RAGE.
So here are some of the specs.
Streamlined lightweight covers standard
Safety cables standard
Weighs less than the AOSS
Infinitely adjustable and tuneable suspension
12+- inches of wheel travel
Cockpit adjustability option (with or without electrical system)
Designed to retrofit with LSA cub style aircraft incorporating a cabane “v” such as:
• Highlander
• Rans S7 with the Roberts Bush Gear
• American Legend Cub
• Savage Cub
• Virtually any experimental 1320 gross cub geared aircraft
Need we say more?
Oh, I guess we do. Don’t worry, this is also being developed for planes exceeding the LSA weight standards. This means Super Cubs ect..
Avweld
John Roberts
(208)573-0714
[email protected]
or
Jason Fisher
(208)899-2755
Lots of hummocked snow on hard ice, noticeably less pitch back with this gear. As in popping back up in the air. I had some pretty good sideloads on one skidding turn at Stanley, stiff there, when I didn't want it mushy. I do have one bushing that moved out of place, nothing to be a problem short term, and a fix for that should be easy now that we know about it. More torture testing to follow.
