From a teaching point of view, I hate big engines and pretty airplanes. It is hard to get the owner of a show airplane to rapidly transition from using tail wheel steering to rudder steering on takeoff. This is necessary to level for acceleration. If he has a big engine he doesn't need to until heavily loaded, or at a high density altitude airfield, or something happens. On landing we need to slow down (tail low) before we get there. When we mush down, or touch down a little fast, we need to level for visibility and good rudder control.
But wait! There are ways to cheat. One is to mount a wooden prop. The other is to use dynamic proactive fore/aft stick movement (not pressure.) When ground speed, relative wind, and buoyancy pick up, push the stick too far forward/pull back/forward/back, etc. to find a level airplane you're happy with. This rapid transition increases precession. If we are dynamically and proactively walking the rudders, we will control precession. This dynamic proactive porpoise is not a problem. Static reactive porpoise is a problem. As we control the longitudinal axis (yaw) with dynamic proactive rudder, we control the lateral axis (pitch) with dynamic proactive fore/aft stick.
The same for/aft stick movement is necessary when landing. As we settle on, or just before with some airplanes, we need to push the stick too far forward, pull back, etc. dynamically until we find a level airplane we are happy with. Waiting and reacting does not help. No wind or light headwind and we are already level touching down, we are way too fast. In strong headwinds or strong crosswinds, we will already be level. We should already be slow. When properly slow (ground speed) in a fairly strong downwind, the tail will likely touch down first. It takes quite a bit of power to fly slow enough (behind the power curve) thus the nose will be high.
