akschu wrote:I'm actually quite happy with my hero 7. I put it in a metal case that accepts a 52mm filter. I put a ND and UV filter on it to slow the shutter speed so that prop doesn't look so terrible, and it's not bad.
I
blackrock wrote:Nice, mind sharing the case manufacturer name or is homebuilt?
akschu wrote:This video is me experimenting with Davinci Resolve and reducing a 60fps video to 24. I think it would have been better native at 24fps with the ND filter, but either way, it's not horrible given it's still rolling shutter:
sierrasplitter wrote:Unless you are filming something that will be special to you for years to come .......just shoot in 1080p . That is if all you want to do is post to youtube.
You wont fill up your SD card as fast, your computer you are using to edit wont struggle with 4K files ect.
Zzz wrote:It's certainly usable, but yeah, you will get more motion blur at 24 fps, which is what you want for that prop. Overall that image is pretty crisp.
One side effect of using ND filters to stop down GoPros is that you can go too far, to the point that the smallest vibrations blur everything. Not just the jello effect but the effective sharpness of the image.
evanr42 wrote:Also worth noting that even though the Go Pros can do 4k, it's generally agreed that their 2.7K is actually the best for sharpness and image quality - so shooting 2.7K, which is less painful on the HDs, then editing/cropping in as needed to get those wings or prop out if you desire and upload in 1080p is usually my go-to. If you want to mount a bigger camera out there, the Nikon Z6 has been making me happy lately for a small camera, am working on a mount of my wing with that guy now, and the Sony RX cams have a better image than GoPros too - but with friends who help me get GoPros at 50% off, haven't felt motivated to go Sony yet.
If you're getting NDs, buy a full set - don't just buy one. Per ZZZ's wisdom, it's easy to over-ND a Go Pro. I'll often have to land and switch NDs after an hour or so of flying, otherwise my footage goes to mush as the sky conditions change.
dogpilot wrote:I have both the Hero 6 and the 7. Not a huge difference between the two, the stabilization is better in the 7, but only at 2.7K. 4K your on your own. There is a new camera on the event horizon for 4k, the new DJI action camera. Exactly the same size as the Hero 7, but also features a front LCD for those who like to watch themselves and some other stabilization features. I too got the metal case with the 52mm filter ring. I also make my own mounts as I find the GoPro mounts somewhat hinkey. I simply made new light guards of 1/8" angle instead of the .025 the stock ones are. I then have a variety of other pieces of angle for either forward facing and straight down. The GoPro app does not seem to want to talk to the camera all the time on the wingtip, neither does its remote. So I have a USB power pak that runs the camera and a huge 128gb card, so it can stay on and record for 2.5 hours.
https://www.dji.com/osmo-action
dogpilot wrote:Since I already have the GoPros, I most likely will not change, nothing earth shattering about the DJI's offering, it is just the new kid on the block. As for the remotes for GoPros...useless, as is the app. More than half the time, they lose connection and never get it back. The WiFi is also a huge battery hog, reducing the already limited battery life. It is why I went to using an external battery that will last as long as my bladder. I just record the entire flight, then edit out what I do not want. The external battery was only $14, the right angle short USB cable was another $5. So their combined cost was less that the questionable remotes, which I wish I never bought.
