Backcountry Pilot • Recommissioning Amphib
14 postsPage 1 of 1
Started to recommission the Scout today for it's trip to Ketchikan. No more fun in the Sun, working late in the dark cold hangar tonight.
Found a small hydraulic fluid leak on the forward left actuator. Will cycle the gear a few times with the panel open to find out what's wrong before taking the aircraft off the blocks. I always cycle the gear a bunch after it's been sitting so no big deal.
There was a small puddle of MIL-PRF-5606H here;
I love my new Verizon cellular data here in Oregon!! Man its fast in contrast to being in Roadhouses, Kona, and Honolulu!
Re: Recommissioning Amphib
Wrapped a small piece of paper towel around the #4 NPT fitting to see if it leaks on the gear actuator (see post #1). So far it's holding about 700PSI with no sign of a leak (about 15 minutes);
(8) spark plugs to clean, gap, test and replace the copper gasket;
Drained preservative oil MIL-C-6529-C ;
Lycoming started first 180 degrees! Running well. Next: cowl, logs, flight... 8)
So where was the hid leak? Did you ever find it?
G44 wrote:So where was the hid leak? Did you ever find it?
Hi Kurt,
The leak stopped! I put a half turn on the NPT. Hopefully it will stay dry.
Will watch the actuator and the hydraulic reservoir closely. Going on test flight tomorrow.... [-o<
Fingers crossed! [-o<
G44 wrote:Fingers crossed! [-o<
Thank you Kurt. [-o<
All the logs are signed and we are ready to fly the little ship...Everything is in remarkably good condition for being close to the ocean. But, I'm not shy with ACF-50 :D
Further updates to follow...
The little ship is flying again. Pretty well too. Please see photography from today on iPAD...
Yaquina Bay:
The famous lighthouse. Notice the strength of the wind, streaks lining up with the gusts:
Too windy to alight on the river for me today;
A couple of kitesurfers at the jetty. Gusting winds to 27KTS;
Evaluating Plan "B" items this morning:
After a (1) hour test flight I am totally stoked. =D>
Very happy to report the hydraulic fluid leak in the left #2 float chamber is looking very dry!! Topped off the reservoir and good to go.
New life raft being stored in right float locker;
Homemade placard rendered with a red Sharpie semi-permanent marker:
Washed the Scout this morning 07:00 PDT. It's VFR, unreal. Decided to blow dry the airframe...
Life is great in a Scout... I departed in about 700 feet, @gross, 100' DA, 11KT x-wind (@ 45 degrees). She climbed @ 90 IAS / 700 FPM
Back in the saddle again..
Verizon mobile WiFi router (internal to iPad) connects laptop to print insurance certificate...
Food from WalMart (2-3 days). I'm cutting back on eating [-o<
14 postsPage 1 of 1
