Backcountry Pilot • Record soaring flight in the Alps
3 postsPage 1 of 1
This is quite pleasant to watch.
Re: Record soaring flight in the Alps
Fantastic.... If you have never gone soaring do it at lest once, its one of the best experiences in aviation.
Try a soaring club and look for a member with a two place high performance plane. I did, retired Delta pilot, ride
cost me the cost of the tow and was up for over an hour.
Michael McGraw offline
As seen on the Online Contest, if you put your courser on the bottom of the graph and move it left to right it'll trace the flight on the map.
http://www.onlinecontest.org/olc-2.0/gl ... Id=1665808
Glidergeek offline
Aircraft: 1968 P206C
DG 400
3 postsPage 1 of 1
