Backcountry Pilot • Recreational Aviation "Call to Action"
6 postsPage 1 of 1
RAF CRITICAL call to action
WE need your immediate help-------- Comment Period Has Been Extended to May 23, 2013
If you haven't already submitted your comment you still have a chance. Please send your comments today!
Background:
In 2012, through a collaborative effort involving the RAF, the USFS/USDA published a new Planning Rule to develop, revise and amend FS land management plans. This rule will replace the previous one written in the 1980s and will be the planning “Bible” for the next 20-25 years. Through a collaborative process, the RAF and others were able to interject recreational aviation and the importance of recognizing airstrips as a valid part of USFS infrastructure into the 2012 Planning Rule.
Recently, the USFS released and is seeking public comment on the proposed 2012 Planning Rule Directives , a key set of agency guidance documents that will direct implementation of the 2012 Planning Rule. The proposed Directives contain agency policies that serve as the primary basis for internal forest planning management.
The Directives are critical to recreational aviation and USFS airfields since they provide procedures and techniques to be used by resource specialists and planning staff engaged in land management planning for the national forests and grasslands. If we can get the proposed Directives to recognize aviation interests, the document will influence USFS planners and managers actions concerning airstrips for the next 20 years or more; and therefore, will positively impact the destiny of those airstrips.
In the past, neither the old Planning Rule nor the old Directives held any direct references to USFS airstrips. Roads, trails, historic sites, and many other common infrastructure classifications were discussed in detail, but not airstrips.
Regrettably, the USFS draft of the new Directives is also devoid of references to recreational aviation or airstrips. The new Directives will control planning on USFS lands for many years; therefore, we need your help to correct these critical omissions in the proposed Directives.
Prior to April 29th, The RAF is asking you to please submit your comments and ideas concerning the proposed Directives via both email, and the U.S. Postal System mail:
USFS DIRECTIVES PUBLIC COMMENT EMAIL LINK https://cara.ecosystem-management.org/P ... ject=30641 (you may have to cut and paste this link into your browser)
Next, postal mail a copy of your comments to:
USDA/FS Planning Directives Comments
P.O. Box 40088
Portland, OR 97240
Note: you can copy and paste into and out of the comments section of the USFS email page.
Here are some key points you can build on while drafting your comments concerning the proposed Directives:
Ø USFS airstrips are an important recreational and operational part of the USFS infrastructure. Please ask the FS to change all instances in the Directives where “trails and roads” are referenced, to read “trails, roads, and airstrips”.
Ø Some airstrips (built on natural meadows) predate historical trails and roads. Therefore, some existing airstrips may also be historical sites; however, no mention of this possibility is made in the proposed Directives. Historic trails, roads, and buildings are discussed in detail, but not airfields. Please ask the FS to revise the proposed Directives to direct planners to explore whether any airstrips in their planning area may have historical significance.
Ø In many places throughout the proposed document, various forms of recreation are listed and discussed. The 2012 Planning Rule mentions aviation as a valid form of recreation. However, the proposed Directives do not mention aviation activities. Please ask the FS to include aviation as a recreational activity in the Directives wherever recreational activities are listed and discussed.
Ø Many USFS airstrips are maintained through joint efforts of the USFS and volunteer groups, (including the RAF). Please ask the FS to revise the proposed Directives to include guidance for planners on the importance of coordinating with volunteer groups within their planning area, when gathering information on airstrips.
Ø The Chief of the USFS, the heads of other agencies such as the BLM, and the U.S. Congress, have all published comments on the significance of airstrips as part of an overall balanced public lands transportation system. Unfortunately, not all USFS planners and managers are familiar with the airstrips within their planning area. Please ask the FS to place greater emphasis on their airstrip infrastructure through direct inclusion of airstrip guidance and instructions to planners in the proposed Directives.
Ø The FS owns the airstrips; it makes little sense for them to be excluded from the Directives. Airstrips need to be an integral part of forest plans. Including them in the Assessment, Land Management, Monitoring, and Wilderness Evaluation Chapters of the Directives puts airstrips on the same planning level as roads, trails, and historical sites when forest plans are being constructed or revised. Please ask the FS to revise Chapters 10, 20, 30, and 70 to place airstrips and recreational aviation on the same planning footing as other listed infrastructure and recreational activities.
Ø Forrest Planners who may not have detailed knowledge of airstrips within their planning area need to be given instructions on where that information can be found. The proposed Directives clearly outlines sources of information when accessing and planning for roads, trails, historic sites, utility corridors, and etc. Airstrips need the same considerations so planners will fully understand airfield planning requirements and issues. Please ask the FS to include sources of information on airstrips to planners by including sources of information about airfields in the proposed Directives.
Ø A revolution is coming within the next 10 years involving inexpensive to purchase, operate, and maintain electric powered airplanes. When this happens, recreational aviation pressures on USFS airstrips will increase. The Directives must provide planners the tools to recognize, assess, and adapt to this increasing demand. Adopting the proposed directives in their current form will not accomplish this task. Please ask the FS to revise the proposed directives to include recreational aviation and airstrips in order to encompass potential future demand on airstrips.
Hints to make your comments effective:
When you write your comments, put them in your own words. Form letters and mass emails that are all the same are usually not counted as individual responses.
Be courteous and give constructive comments. FS planners have worked hard to make the proposed Directives the best they can. We’re helping them see items they have overlooked.
Be sure to email your comments ASAP and for certain, no later than April 29, 2013.
To date, the RAF has been very impressed by the collaborative process the USFS/USDA has put together to get this tough job done. There are a lot of dedicated FS folks out there who just don’t think about aviation when planning. They’ve never been required to do so; and, they may be ignorant of the aviation thing we do. Our purpose is to change that situation so every time a plan is built or revised, any airstrips in that area will be included and provided for within that plan. That’s not happening now; but, with your help, we can change that situation.
Thank you for your continued support and participation in the RAF mission. Taking a few minutes now to assure recreational aviation's inclusion within the USFS Directives is a quick and easy investment for you; but, it will yield long term rewards for your children and grandchildren who may someday wish to enjoy the same aviation privileges you have. Helping now goes a long way towards protecting, preserving, and creating recreational airstrips on USFS lands. Those are the reasons you joined the RAF; so, let’s get this done.
Questions?
drifter offline
Re: Recreational Aviation "Call to Action"
I am working with the Recreational Aviation Foundation regarding the above "Call to Action". I need your help in identifying ALL Oregon U.S.F.S. landing sites which might be either current or previously closed runways. The current Forest Service inventory of airstrips, which you'll see below, I can't help but feel is slacking....there have got to be more strips, or commonly used landing surfaces, out there. Remember these are USFS landing sites only. If you're not sure whether they are USFS or BLM, please reply by the name you call the site and the lat./long. and I'll try to figure it out.
The current USFS acknowledged strips are:
1. Cache Creek (no id.) ------- Willowa-Whitman N.F.
2. Dug Bar (no id.)------- Willowa-Whitman N.F.
3. Fall River ------- Willowa-Whitman N.F.
4. Lord Flat (no id.) ------- Willowa-Whitman N.F.
5. McKenzie Bridge (OOS)------- Willamette N.F.
6. Memalosse ((25U) ------ Willowa-Whitman N.F.
7. Pittsburg (no id.) ------- Willowa-Whitman N.F.
8. Rager Guard Station --------- Ochoco N.F.
9. Red's Horse Ranch (no id.) ------ Willowa-Whitman N.F.
10. Salmon Bar (no id.) -------Willowa-Whitman N.F.
11. Silver Lake (45S) ------- Fremont-Winema N.F.
12. Sluice Creek (no id.) ------- Willowa-Whitman N.F.
13. Temperence (no id.) ------- Willowa-Whitman N.F.
13. Toketee State (3S6) ------ Umpqua N.F.
In your response to this request please list the common name of the strip (if known) and the lat./long. Please submit your comments to the Forest Service using the information and the link provided in the post above. This is really important stuff if we want to have more place to land and enjoy on our publicly managed National Forests. It's important to note that I'm not asking if you have landed on these strips, just that you have knowledge that others have.
Thanks,
Phil
drifter offline
Cold Springs Guard Station Landing Field
CW
clippwagon offline
Great!
Cold Springs appears to be in the Ochoco National Forest at 44 20' 33"N, 120 7' 37"W . I hope we're on the start of a "small" roll here. I really appreciate the reference and would like to encourage others to try to remember others.
Phil
drifter offline
45*02'25"N, 119*,34',16"W There is an old airfield with two runways at least 1/2 mile long each. A local rancher told me he thinks they used to fly fire bombers out of there long ago. I call it Bull Prairie. It is about 6.5 Statute miles NE of Bull Prairie lake in the Umatilla National Forest.
Homeboy offline
Thanks Homeboy,
I found it exactly with those coordinates on my NGS topo series maps where it's referred to as Big Rock Flat airstrip. It does, in fact, show it to be in the Umatilla N.F.
Let's keep looking....this is important for all of us.
Phil
drifter offline
6 postsPage 1 of 1
