Now that I think of it, I’ve had it for over five years…maybe it’s mine under shop rules
Tried to call around for a new one and they don’t make them anymore?
NunavutPA-12 wrote:Spend your money on a proper and safe engine heating system like Reiff or Tanis.
NunavutPA-12 wrote:I have one of those Chinese, diesel-fired heaters. They work okay and put out a fair amount of dry heat for their size. They are slow to start and the glow plug and fan sucks a fair amount of amperage from a 12-volt battery - but they do work.
I've heard of a fellow who uses a 1000-watt generator to run his (Reiff of Tanis) heating system. He puts the generator INSIDE the airplane with the exhaust to the outside through a length of skeet tubing. Apparently, the heat from the engine warms up the cockpit. I just might try that1
MTV is right, electrically heating the engine does take some time. Four hours usually does the trick for me even at minus 30 with a good engine cover. I have no electricity at my hangar or at my cabin. The one kw Yamaha works fine but, at 30 pounds is, I imagine, heavier than the Red Dragon. But the generator will run on avgas, and I always have plenty of fuel with me. And also - does the propane flow well enough at very low temperatures to feed the Red Dragon burner?
gahi wrote:I am going to build a setup using one of these chinese diesel heaters. I have one in a cargo trailer and have been really impressed. Runs on a 12v battery like a red dragon. You could run a return air out the cowl if you want. The exhaust goes out its own port, so the heated air is dry. Not sure what the degree over ambient raise is without a return air.
Brian M wrote:I've got two red dragons that I never use. If you're going to be down in the Anchorage area at any point, let me know and we can figure out a fair price. They're not brand new, but they are lightly used.
akavidflyer wrote:I have been using these for several years. They heat my boat, enclosed trailer and the plane preheater. I use the 8KW heaters and get 175 degree air at the end of the 6' scat hose at -20 ambient.
gahi wrote:akavidflyer wrote:I have been using these for several years. They heat my boat, enclosed trailer and the plane preheater. I use the 8KW heaters and get 175 degree air at the end of the 6' scat hose at -20 ambient.
Is that using return air duct, or just pulling outside air?
