Canalguna wrote:How much low power did you flew with floats MTV? I'll try to go 70% after going LOP, but no more. Was ending with 50% after BMP but it won't hold altitude/speed with such a drag from my floats.
I had wondered a lot about investigating a turbo removal, but it seems swapping to a 550 is the only reasonable thing to do.
I ran the IO 550 on the 206 at pretty low power settings. LOP burning 13.2 or so gph. This was on the VERY large Wip 4000 straight floats. And operating generally from landing sites that were lower than 1000 msl. At temps, however ranging as high as 100 F. I regularly climbed over 5 to 6000 ft mtn range enroute.
I’ve forgotten specifics, but that engine had a hard upper percent power, above which NO leaning was permitted. That was the risk letting a pilot who was routinely flying an IO-520 fly the 550, without strict and stern lectures on leaning. I think the upper limit was 70% power….. So, the IO 520 guy gets in the 550 airplane, and cruises at 25 square….a pretty common setting for 520. But, that pier setting in the 550 is….like..80 some % power. So 520 guy leans it down to 16 gph, which is what he’s used to, and promptly smokes a bunch of cylinders.
The point is, the 550 is a continuous rated 300 hp, where 520 is 285 continuous rated. Max rpm on 550 is 2700, on 520 it’s 2850, to get that 5 minute 300 hp rating. But, most 520s never make 300, due to the way the engine was certified.
Very different engines, and need some knowledge to operate. But, the 550 is magic…a 300 hp engine that actually makes 310. And that engine, operated intelligently, loves LOP.
