Want to replace the carpet on my plane with a utility type material.
What do you guys use for your utility interior?
What material and where do i buy it?
motoadve wrote:What material and where do i buy it?
Pusher wrote:Battson,
Thanks for the info. Did you use a 16oz marine carpet? Most of the marine carpets I have seen are glue down carpets. How do you keep your carpet staying in place?
A1Skinner wrote:Looks great Jim. Did you just make your own checker plate covers or can you buy those? What brand of flooring?jaudette wrote:I used this in mine and love it!
175 magnum wrote:"I have been considering going back to carpet. Most of my flying is to beaches which involves allot of sand in my airplane. I have Lincoin flooring now. It is nice but the sand all ends up underneath it. Capet seems to trap sand better... "
I switched back to carpet ten years ago for the same reason and it works great. My carpet has a Velcro join under the front seats and it takes 5 minutes to remove the front carpet and shake it out. I keep looking to see if I packed any gold in with the mud , no luck so far.
