Backcountry Pilot • Reskinning a 206 Horizontal
8 postsPage 1 of 1
Skinning a horizontal is a lot of work. Very labor intensive.
A jig is very important. Being able to work on it vertical also makes all the difference in the world.
Skins are flattened in order to copy efficiently.
New skins fabricated
Nice tight joints
Test fit
A Riveting Experience
Similar to riveting a wing, you work from the leading edge, aft.
Ready to pull and send to paint booth.
richpiney offline
Re: Reskinning a 206 Horizontal
Great work! How did you get the leading edge bend? Just by using the rivet holes to pull it around?
jrc111 offline
The bends are made in a brake.
richpiney offline
Thanks for sharing, it is nice to see how it is done. Looks like satisfying work.
Would it be easier if you could get the jig a little higher? As I get older I spend more time getting work at a comfortable height and it is time well spent for me.
daedaluscan wrote: Thanks for sharing, it is nice to see how it is done. Looks like satisfying work. …..
x2
Great work! I had my Skywagon stabilizer reskinned last winter by Bentley Air in Bend Oregon.
https://backcountrypilot.org/community/forum/latest/tanalian-aviation-horizontal-stabilizer-mod-21275
I installed the Tanalian Aviation replaceable leading edge STC. It's probably my favorite mod on my plane.
They make it for the 206 as well.
Scolopax offline
It is so nice seeing quality work. You obviously care about the finished product. The 182 project your doing is equally impressive.
=D> =D> =D> =D>
akgreg offline
Aircraft: Yes
Nicely done [emoji1360]
Aryana offline
Aircraft: 1955 Cessna 170
8 postsPage 1 of 1
