CamTom12 wrote:I don’t think the TCDS or data plate specify that number as maximum advance. My O-320 has it listed as just “spark advance,” which in the certified world means that at Wide Open Throttle (WOT) the advance should be at this number (or, with a fixed-timing mag, it should *always* be at that number).
Reducing timing advance will move the cylinder’s peak pressure to later in the the piston stroke, which gives less time for that pressure to push on the piston/connecting rod/crankshaft. This results in less power but also less stress, which can help lower temperatures.
I can’t think of any negative impacts to reducing timing by 2° other than reducing power a smidge. Having said that, I don’t think that 2° will make a significant difference in temps, either.
If the engine is supposed to fire at 22°, I’d be much more interested in figuring out why we can’t keep it at a nominal temperature at 22°. Is it a standard installation? What’s different about your engine install from anyone else’s? How are your baffles? Fuel pressure/flow?
Hmmm, that’s a good point, we shouldn’t have to retard the ignition to keep the temps lower.
Actually I feel like my Fuel Flow is a little low
Im getting 25.7gph at Full power
But mechanics say it’s enough
