TxKiger wrote:Incoming thread drift... Anyone know the largest size tire that will fit on a standard 1957 182 fork?
Jeredp wrote:TxKiger wrote:Incoming thread drift... Anyone know the largest size tire that will fit on a standard 1957 182 fork?
Not sure about the 182 but my 56 172 would not take anything larger than a 5.00x5. Check the parts book and see what options it shows. Thats your best bet
TxKiger wrote:Lol at nosedragger... Thank you Jared and Tango for the info. That's what i thought but I wasn't quite sure.
Jeredp wrote:TxKiger wrote:Lol at nosedragger... Thank you Jared and Tango for the info. That's what i thought but I wasn't quite sure.
Fyi, I just saw a heavy cessna fork with a 7.00x6 and an airglas fork for sale on anchorage craigslist
WWhunter wrote:What is the difference between the heavy duty Cessna and the airglass fork?
akaviator wrote:WWhunter wrote:What is the difference between the heavy duty Cessna and the airglass fork?
The HD Cessna fork can run up to a 7.00-6 (depending on manufacturer), the Airglas fork will handle an 8.50-6. The HD Cessna fork is basically a bolt on, the Airglas requires the nose strut to be shortened. That and some extra $$$ for the Airglas.
Mark Y. wrote:Just finished the install on my 172N. The new block fit the strut tube tighter than I assumed. Even with freezing the tube in a cryogenic freezer and warming the block i still had to end up using the press to install. I had asked to have spacers for the brake discs sent, just in case there wasn't enough sidewall clearance. The spacers were wrong for my 40-113 cleveland mains. Luckily i had enough clearance with out using the spacers. Otherwise very straight forward to install. I wish the through bolt they supply was longer and had spacers so a standard cessna towbar could be used. Very happy overall, I flew the plane in to my home hay field to do the conversion with the small tires and got hammered pretty good. I flew out after installing the 850 mains and 800 nose and hardly felt a thing. I was reading about how the 850s have more cross sectional area for flotation than the 800s, but this doesn't appear to be the case the GY 800 supplied seems just as wide as the GY 850. I purchased everything from Todd at Hitchcock Aviation. Well worth the money. Now my plane is stored at home and not at the local airport.
Troy Hamon wrote:I will be the other voice...I find 850s are a substantial improvement compared to 800s. I have flown Tripacers with 800 mains and mine has 850 mains. Big difference in my opinion.
EastTexasPilot wrote:...BTW it's taking forever for my grass to grow but I finally figured out why so it's not an issue.....
