whee wrote:I'm getting to the point were I need to figure out how I'm going to fasten things together. I know most BH builders use nut plates galore but I hate installing nut plates, like really really hate it. My intention is to use only rivet nuts and tinnermans. What problems do you all see with this? Having a bolt corrode in a rivet nut can cause some problems because the rivet nut can break loose and spin with the screw but not using rivet nuts in areas susceptible to corrosion will help.
Hoeschen wrote:Ever heard of clickbond fasteners? Very widespread use among military aircraft. These things ain't cheap but very fast and slick. Several types to choose from. I used several of the nut plate type and some of the zip tie hold downs on my RV.
Helpful in places without access to buck or squeeze a rivet. I did my wing tips entirely out of click bonds (in lieu of 100+ nut plates) to save time. Much lighter too
http://www.clickbond.com
I can't remember for sure but I think the only place on the wings that doesn't have nut plates already installed is the wing tips. I got lucky on that one. 6MK had tinnermans holding the floorboards down, which I took up a couple times; they seemed to work fine.Battson wrote:I didn't "like" nut plates, but we didn't know any better either. After the first couple of hundred, they weren't so bad. I use the plates themselves and a cleco as a template (one use only, then install). I found they were easy for a helper to install with only a few minutes of training, provided I drilled all the main pilot holes for the screw locations first.
I would advise against using Rivet nuts or Tinnerman nuts anywhere that's truly blind (like the floorboards, rear bulkhead, inside the wings). If they fall off and disappear into the tail section (Tinnerman), or if they start to spin (Rivet nut), you will wish you spent an extra two minutes installing a nut plate in those places.
Yes installing several hundred nut plates on each wing is a total drag, about two days work. But I wouldn't want a Tinnerman there. The screw thread would be rubbing against the alloy and could lead to excessive wear, or even cracking, maybe. Same goes for much of the cowling where the vibration is high, I doubt a Tinnerman or Rivet nut would last as long as a nut plate.
That/s my opinion. Glad I did use nut plates now, in hindsight, when I come to do maintenance. I wasn't happy installing them all.
I don't envy you with all those wing nutplates in front of you... Before I started, I once calculated how many holes I had to drill, wish I never did that.
whee wrote:Loctite has some products that would greatly help secure a rivnut. Combine that with some anti-seize and they might be ok.
N-Jacko wrote:whee wrote:Loctite has some products that would greatly help secure a rivnut. Combine that with some anti-seize and they might be ok.
Yes, that has worked for me. Loctite, stainless screws, a whiff of Kroil on the thread, annual disassembly, and keyed rivnuts where spinning would really be a PITA.
PJ
Pinecone wrote: You're a young guy. You'll own this airplane you're building for decades. Build it to be serviced, and to last.
