Robinson impact resistant windshield
It takes strength and fortitude to beat the air into submission.
Wed Dec 16, 2020 11:11 am
This is amazing. Seems like a tech approach that should be incorporated into fixed wing builds too to protect against birdstrikes (and maybe drones?
2854
Wed Dec 16, 2020 11:37 am
2093
That would be cost effective in pipeline 172s that fly around 1200 hours per year and need a windscreen change every couple of years. Heat crazing and pitting that cuts down on good visibility is the most common, but an unlaced with safety wire innocent looking crack will eventually cause part of the windscreen to come out. Been there.
4972
Sun Dec 20, 2020 12:07 pm
Is it any safer if you get smacked in the face by your windshield?
cdgarg offline
100
- FindMeSpot URL: https://share.delorme.com/ChristopherGarg
- Aircraft: 1953 Cessna 180
Plexiglas cracks and large pieces break off and enter the cockpit with the strong relative wind. So yes, missile damage is worse short of being knocked out by the airbag type windscreen. Perhaps a bit thicker material for airplanes. I lost vision in my right eye when when the windscreen split at an unrepaired hairline crack and large pieces broke off and hit me. I have flown many with small holes drilled and the hairline crack stitched up like you tie your shoes with no problem. Brenco's owner, Uncle Rick, was more interested in perfect paperwork and cosmetics.
4972
Zzz wrote:This is amazing. Seems like a tech approach that should be incorporated into fixed wing builds too to protect against birdstrikes (and maybe drones?
Yes, it's very impressive. It's also cheaper (and provides a boader spectrum of hazard mitigation) to spend $1700 on a helmet and face shield... and wear it!
PapernScissors offline
419
- Aircraft: Cessna 172
Sun Dec 20, 2020 10:08 pm
Good point. The windscreen thing was before I wore glasses. Sometimes wore the SPH-4, but not always.
4972
On a bad day you have to dodge both the bird and the salmon. On takeoff from my local airport.
- BB3A719F-EE4A-4020-B890-002D54779F68.jpeg (172.63 KiB) Viewed 759 times
Karmutzen offline
711
