Any ideas what would make this happen?
d.grimm wrote: I've seen them worn on the inside, but never a hole.
Don't the new 0-200's have set screws in the boss to keep this from happening?
shorton wrote:Check to make sure the top of the valve stem is perfectly flat, if it has a bevel to it that will make the rocker arm torque to the side a tiny bit each time it strokes and that MAY make the bearing "walk" sideways. Uneven wear on the bearing surface of the rocker arm itself can cause the same thing..........
907Pilot wrote:It's from the bearing that holds the rockers in place.
oldtech wrote:......never saw one through the cover. Weird!
