Backcountry Pilot • Roller Rockers
Roller Rockers
6 postsPage 1 of 1
Roller Rockers
Is there anyone out there manufacturing roller rockers for Continental engines? Specifically I have an IO-470-F in a 1961 C-185.
Jay Smith offline
Re: Roller Rockers
I've heard no, but if you do find them please post the details.
Skalywag offline
Re: Roller Rockers
I found this with a google search, give them a call and see what they have specifically.
http://www.performanceengines.com/components.html
Dale Moul offline
Dale
Gravity Strikes Again.
Re: Roller Rockers
The STC did / does exist;
http://rgl.faa.gov/Regulatory_and_Guida ... t=se8594sw
Good luck finding a set. I would be interested in finding a set myself...
I *think* the AD on them killed the rollers... :cry: the poor valve geometry on these engines lends itself to rollers.
Rob offline
Re: Roller Rockers
I took a set off of an IO520F that had about 500 hours on them and they were/are immaculate. Thanks to the AD, I can't use them on my certified aircraft. Maybe someday I can put them on something experimental. I sure feel safer now. #-o
CAVU
CAVU offline
Re: Roller Rockers
One thing to check on the used roller lifters you do find is whether they have been involved in a prop strike with engine stoppage. I have a Superior Air Parts XP-O-360 Plus which uses roller lifters. Regardless how good they look the manufacture recommends full replacement of the roller lifters after a strike that causes engine stoppage. They are treated like the Unison/Slick mags in that situation. Start over.
There is no reason I should know that. (Disclaimer)
dirtstrip offline
6 postsPage 1 of 1
