Mostly out of curiosity, and yes a tax payer forced funded pad is best, but
Is there a rule of thumb type math figure for calculating if a roof can successfully handle a helicopter?
Rob wrote:If a state, county, or other special circumstances haven't dictated a higher roof load, the minimum design criteria will be 20, 30, or 40 pounds per square foot depending on what snow load zone you are in. You can do a search for a snow load zone map, but it is basically southern states, the rest of the country, and then the tip of the northern states.
From there the math is easy, if planning for a Jet ranger to operate in the middle of the country at a typical weight of 3000#, you're going to have to build a pad of at least 10'x10' on the roof. You will need a pad regardless of the craft or roof load capability in most cases anyway, because you need to get the load spread across the trusses, beams, rafters or whatever load bearing members it has. Almost no actual roofing substrate is designed to be load bearing. Otherwise you will be limited to landing directly across the members only, and that in itself will get pretty limiting as most skids (or worse wheels) don't give you very big foot print. Build a lightweight pad capable of spreading the load and even a manufactured home will carry your bird, our trailers do with less effect than the fuel or water they haul on them as well.
Take care, Rob
